>I have an upholstered couch that's about 5 years old, moderate use. Frame, upholstery, etc all look/seem brand new, but apparently they used cheap foam in the seat cushions, because both are quite flattened. It's not the springs underneath, they're fine. Since everything else is good, I'd like to replace the foam inside the cushions, pretty easy as there are zippers. I'm sure foam rubber is like anything else, with good and not so good varieties. I thought with all the furniture making that goes on around here, maybe someone knows about foam rubber. Is there a particular variety which is firmer/stands up better?
TIA
Dan
Re: OT: anyone know about foam rubber for cushions?
>Good Afternoon Dan,
When I did upholstery, I bought the foam from an upholstery wholesaler, with whom I had an account. That way I could be sure that what I installed was suited for the intended use. There are various grades/densities and materials used in "foam", and I didn't want to buy a pig in a poke. I would check the Yellow pages and B to B, and contact a supplier near to you. Go with their guidance. I would tend not to buy from fabric stores and outlets. I'm sure they are honest people, but may not have comprehensive knowledge of foam which they sell. Also, they want an arm and a leg, and I am down to just two of each.
George
>...isn't much, but I just replaced a foam rubber cushion in an old stuffed chair and it worked fine. I bought a block of the appropriate thickness of foam rubber (in this case 4") at a large fabric store. As George mentioned, fabric stores are not upholstery specialists and tend to sell the cheap and simple DIY materials -- foam, batting, etc. They only had one durometer of foam available, whereas in the upholstery division of the contract furniture company I used to work for, we had many different durometers for different seating products we made. You might want something softer or harder than the stuff they sell at the fabric store.
Another open question about upholstery is whether or not to use thin layers of cotton or synthetic batting around the foam and in the corners and crannies of the slipcover. I'm sure there is a decision tree here, but I don't know the reasoning for or against this practice.
One thing I've found is that there are always friendly local mom & pop upholstery shops around that will take the time to discuss these matters. You may even find that it is a lot less expensive than you think to have these folks actually do the work for you.
Ellis Walentine, Host
Nat Robison
>It sounds like you want to do this project yourself and if so, I can't give you much guidance. However, the quickest and cheapest route might to be have a re-upholster do the job. I just had a chair re-done at an upholsterer and we had inquired about having it slipcovered or completely re-done (stuffing, cushion foam, etc). The cost difference between the two was about $150. A job like that might only take a skilled upholsterer an hour and $30 worth of materials.
>I have replaced lots of foam over the years. Any moderate city will have a place that sells foam for upholstery. Ask at a place that does upholstery if you can't find it in yellow pages. These places have stock pieces and they will saw out what ever you need. Even fabric shops carry it or can order. I have never seen it branded, so it may all come from the same place. I have always presumed anyhting I buy as upholstery foam is equivalent.
>I second the recommendation that you look for the supplier, not a local craft store. If you have ever shopped for couches you have noticed that sometimes you sink in, sometimes it is like a rock, and that you can get a wide variation in the density of foam. When I last bought some, I told the owner I wanted the densest foam he had, he told me I was wrong, then he set me sit on a piece and I agreed with him ( it was like a rock ) So my suggestion is that you try to find a place that supplies to the local upholstery shops and ask to sit on a few different peices to make sure you get what you want - btw, the back cushions are usually much less dense than the seat cushions so if you are replacing the backs, you should try leaning up against that foam. Barry
Dan MItchell
>Thanks for the replies. Good to know about the "high density" foam being TOOOO dense, since thats probably what I'd have opted for ;-/
There is a place around here that deals in foam, even having a reference to fixing "man eating sofa cushions" on their sign. Easiest thing would be to just bring them the cushions, but I don't want to pay "re-upholstery" prices for what amounts to just shoving a slab of foam through an existing zippered opening. I'll give them a call.
