Re: sound proof insulation for basement
Scott in Montana
>Hello Steve,
There are lots of things you can do to keep the noise or energy in your shop and out of other areas.
Leaving the joist spaces open is a good thing as it will trap and dissipate a share of the mid to lower noise spectrum. Inside these areas you should install a minimum of 3.5" of fiberglass acoustic insulation. You could use standard fiberglass thermal insulation but it will trap heat in your shop rather than letting the convection to occur and depending on the design of your heating system this could cook your shop and cause the room above to be chilly. Anyhow, if you desire to install a smooth surface below that to prevent dust accumulation, you could use sheetrock, rigid fiberglass, or rigid styrofoam insulation. If you use sheetrock or any other heavy material you will want to use drywall standoffs or "Z" track made to isolate the material from your joists or floor above.
The transducer of noise that many people miss is the bearing walls in their basements. Any wall with a load will vibrate like a violin string with tension on it; at a much lower frequency of course. This vibration will not only carry noise to your main floor but all the way up to the upstairs or attic. A general noise mitigation solution for these walls or posts is to sheetrock them using standoffs and two layers of 1/2" or 5/8" sheetrock with a layer of silicone squeezed in between or a layer of 1/4" sponge foam. This will deaden the low frequencies before they reach the bearing walls or posts. The silicone or sponge foam keep the two sheets from rattling and will also kill vibration due to being a dissimilar material. There are specific sheetrock materials used for specific frequencies, but the costs can be staggering.
Erratic shapes also help to dissipate noises. So if you have a long straight wall, break it up by hanging some things on it. (the perfect excuse to buy more tools and tell your wife that you are just trying to make her life more peaceful). The shapes break up sound waves in the air and the different weights load the wall erratically and break up the waves in the wall
And I guess finally, if you have the opportunity to frame a new wall for your shop, don't make it parallel to the others and this will help dissipate sound much quicker as well.
If you still have annoying noises after trying some of these fixes, you might borrow or rent a spectrum analyzer/sound pressure meter from a musical instrument or sound reinforcement store it would show you your exact problem frequencies and their amplitude. Once determined you can research the remedy from there.
I've written this quickly so I'm sure I've overlooked a few things, but this might get you started.
Good luck!
Scott
