Re: Very OT - home musty odor after extended flood
>Without seeing it, it is difficult to tell what you should you do.
If the conditions are severe, tearing it down and starting over may not be out of the question.
Inspect it carefully. Mold needs four things, Oxygen, warmth, a food source and water. So do we. The one we can control is the moisture. Having allowed the house to get wet allowed the mold to get started. It turns out that you must let the moisture get exceptionally high for a number of weeks to burst the spores and let it get going. Once it is growing, it is difficult (nearly impossible) to dry out the house enough to actually kill the mold.
The current wisdom seems to be to dry out the house and clean it thoroughly to remove the mold. Just took some training on this. The company that was explaining the technique used baking soda in a sand blaster and blasted the mold off the surfaces. This process also includes a vacuum system to suck up the soda and debris and then a separate vacuuming with a HEPA vac. There are others that use frozen carbon dioxide to blast the mold off the surfaces.
I failed to mention that the first thing is to remove and throw away anything like carpet and drywall etc.
There are companies that can come in and clean the interior of ducts.
The problem is that the industry is fraught with con men and wild unsubstantiated claims. We are very much in the snake oil phase.
The cleaning above is very expensive, and does nothing to assure you the mold will not simply re-establish itself. To prevent it returning, you must modify the habitat. Lower the moisture content below the level that will sustain the mold and keep it low.
You are right about the exterior. The grading must slope away from the house, preferably about an inch (or more) to the foot for about ten feet. As mentioned by others, the real deal here is to dig up the exterior and do it right. (Install excellent waterproofing and drainage at the footing level) Doing exterior water proofing on a finished house is expensive and very disruptive. You can try removing some of the topsoil around the perimeter and replace it with a foot or more of clay soil (called Clay Capping) and make sure the clay slopes away form the house, but once the water has established paths into the house, it is difficult to convince it to go elsewhere. The difficulty and expense of doing this well and on the exterior is the genesis of the interior systems such as B-Dry. (The only people that really promote the interior systems are the people selling them.)
We used to suggest you treat the interior with a bleach solution. This is now frowned upon. The bleach does usually kill the existing crop of mold, but does nothing to prevent it reoccurring. It also may break down or weakening the structure of the molds and allow them to float out into the air, where you inhale them. Apparently your system can not tell the difference between live mold and dead mold, so the bleach may be a bad idea.
The other rule of thumb is that if there is less than ten square feet of mold, you can clean it up yourself, more than that and you should bring in the pro's.
The professional you want to deal with on this is and Industrial Hygienist. Not some local Home Inspector who took one day of training and are working as shills for the mold industry.
Check out the web site at BuildingScience.com. Joe Lstiburek is the guy behind it and he may be the best building scientist in the country.
The Home Inspection business has seen a number of things over the years that generated huge excitement. Aluminum wire, lead paint, PB pipe, Treated Wood, Etc. etc, and now Mold. In my opinion we are a bit over the top on it, but the reason I stay out of it is that it affects each of us differently. I have been going in wet moldy basements and dank crawls spaces almost every day for over twenty years, with no apparent ill effects, other than I used to be taller and better looking. OTOH, some people are severely affected.
Your son needs to take his family to the house and let them spend an hour or two. If no one is bothered, then he might want to take the house. If someone sniffles or sneezes, or their eyes water or swell, some reaction to the mold, then get out and don't do it.
Its a brutal process. Stripping out/cleaning, and fixing the water problem. An early step is to get the place dehumidified, either by getting the AC going or renting big dehumidifiers or both.
