What is side sharpening? *LINK*
Brian Gray in Sandusky, OH
>I was looking through the Japanesetools.com website and saw the link below.
I've seen Harrelson Stanley's stuff before, and he definitely knows what he's talking about.
But I have no idea what side sharpening is.
Sounds like a new technique.
Anyone know what the concept is?
Side Sharpening
Re: What is side sharpening? *LINK*
Dale Lenz
Re: Another way...
Dale Lenz
>of skinning a cat. Might try Google: side side sharpening jig. I've free handed side sharpening a little bit. Another method to add to your arsenal.
Using the side of the grinding wheel
Dave Bair, Eaton Rapids, MI
>instead of the face. If you don't use the right type of wheel, or get it too thin, the wheel can disintegrate at several thousand rpm.
Teresa Jones
>I saw Harrelson demostrate this technique in a class at Woodcraft.
In a nut shelf, it moves the blade being sharpened side to side instead of back and forth along the stone. I'm not sure if that makes sense but in effect the "scratches" run parallel to the blade edge instead of perpendicular.
There is a heap more to it than that of course. Another sharpening technique he embraces as preferable to others.
TJ
