OT once again... how to wire a trailer
Tom
>Sort of. I have an 02 IMpala, the first vehicle I've had that apparently nobody has made a simple plug in wire harness for. I have a simple 4-flat connector with 4 wires coming off, but I have no idea how to connect it to my vehicles wiring. The four wires are labeled ground left (white), left turn (yellow) and right turn (green). The black/brown wire is unlabeled, as far as I can see. Each of my cars rear lights have three wires going into the plug. I'd like to have an idea what I'm doing before I start cutting and splicing my car's wires... any ideas?
Re: OT once again... how to wire a trailer
John_in_Az
>Tom, your four wires on the female plug that you wire to the car are: Running lights, left turn, right turn, and ground. Wire the car using whatever color you want for each function, then individually connect each of the trailer wires to the proper plug position on the male trailer plug. Start with the ground because without a good ground you will have trouble i.d.ing each of the trailer lights. Good luck, John
John_in_Az
>I need to add that you need a way to i.d. a wire that has voltage by using a volt meter or test light. I probe the wire that I want to i.d. with a pin and connect the meter to it. That way I don't damage the wire too much trying to see what is what. John
Little more info..
Tom
>My trailer is already wired (I probably chose the wrong title for the thread). It has a 4-flat connector. I bought a female 4-flat that I need to connect to my car's wiring. I'm just not sure where to splice each one. I'm guessing:
The ground (white) can be screwed anywhere onto my car.
The wire labeled left will need to be spliced onto one of the three car wires going into my left tail lamp assembly. Which one though, or how do I figure it out?
The wire labeled right will need to be spliced onto one of the three car wires going into my right tail lamp assembly.
The brown/black one would be the running lights, right? Does it matter where I make that connection and how do I figure out which wire it goes to?
Re: Little more info..
Bill Howatt
>The wire you want is the stop/turn-signal wire. Unless your car has separate turn signal lamps the stop filament is used as the turn-signal by the flasher interrupting the voltage to the stop filament to create flashing. If you have separate turn signal lamps on the car and not on the trailer then you need to buy a gizmo to combine the turn signal/stop lamp voltages for the trailer which usually doesn't have separate lamps.
It is very likely the colors on the trailer connector match up with the ones in the car wiring harness these days. As long as you get the ground wire right you can't really damage anything although it won't work as inteded. IIRC, brown is the color for the tail lights.
If the colors don't match this is a case where having a voltmeter and somebody to put on the brakes and flick the turn signals is real handy. Also, turn the ignition on when when testing, some voltages may not be present with the key off.
Bill
Re: Wait, Wait, Wait..... *LINK*
Kneale Brownson dreaming of snow in N. MI
>Your car's tail light wiring probably is insufficient to carry the load of extra lights, like the lights on the trailer.
You should be using a relay that has its own 12-volt power source and gets triggered by signals from your car's light wiring.
They're generally called power modules or converters. They get their power from a fused line from the battery.
In the days of yore, when automakers didn't concern themselves so much with the weight and cost of copper wires, vehicle wiring generally was robust enough to carry the load of extra lights like trailer systems, but today's vehicles almost universally use too small a wire to accept additional loading.
Most serious auto parts or trailer supply stores carry power modules, and many have versions designed for specific model cars. You may find something that plugs into your existing wiring, other than the 12 volt source, without requiring that you break down the insulation on your wires trying to figure out which wire does what.
Otherwise, I get my supplies from etrailer.
etrailer
I agree
Lee Schierer - McKean, PA
>Modern cars do not use a flaser relay to blink the lights and the extra current draw can damage the circit for your turn signals. It used to be possible to connect the turn signal and brake light functions into one wire for the trailer using two diodes on each side of the car. The diodes would prevent the current from back feeding the other circut. It also resulted in a pulsing (bright dim) turn signal on the trialer when the brakes were also activated. I did this for many years on my Toyota and Mazda Pickups.
Lee
Tom
>Thank you all.... I got it done this morning. Everything seems to work well. I think in the future, I may choose to save a little money and get the simple hard-wired adapters for about $3 instead of the plug in adapters for $25 and up. Now that I know what I'm doing, it really isn't any harder or slower to hard wire a harness. Thanks again...
