Reading your boards- Growth Rings
Bill Tindall, E.TN
>Reading your boards Growth Rings
Growth rings tell a story beyond how long the tree lived. How fast a tree grows strongly affects the appearance of boards sawed from it, especially so for ring porous woods like oak, ash and walnut. In the spring these species grow quickly and add a porous layer of wood. Late in the year growth slows and a dense layer of wood is added to this porous layer. The sum of these layers is one growth ring, or one year�s growth. The density and color of these layers are different. The growth rings show up on the surface of the board as alternating bands of light and dark color and alternating bands of porous and nonporous wood. If a tree grows slowly these bands will be more closely spaced than for a fast growing tree. This difference in spacing will change the appearance as show in the picture.
The tree that produced the left board grew about �� per year compared to the right where the growth was a scant 1/16� per year. In fact, the growth rings on the right are so closely spaced they can not be see in this reduced resolution picture. Note the difference in appearance of the two boards. Veneer log buyers used to be very picky about the growth ring spacing of the logs they bought because they were buying longs to yield a particular appearance in the veneer. I once bought some very fine oak white oak logs that had been rejected for veneer because the growth rings were too close.
Less apparent is the difference in working properties. Rapid growth ring porous wood will be substantially more dense than slow growth, as well as harder. I have seen white oak boards where the growth rings are less than 1/16�and it is as light as poplar and as soft to work. I am currently working some very slow growth walnut that is less dense than average poplar lumber. Slow growth wood shrinks less upon drying. Slow growth wood will not be as strong as faster growing wood because the cells formed in the spring are thinner and larger than the cells that form later in the growth season.
Of all these factors that differentiate faster growth from slow growth wood, appearance is the most important in building furniture. When matching pieces it may be important to choose boards that have grown at approximately the same rate to get a good match in a panel or table top.
