Porter cable omnijig tuning
Evan McCarthy
>I have the porter cable Omnijig, and I am making some dovetails on this jig for the first time. The material is 1/2 inch baltic birch plywood, which is not quite 1/2 inch.
So I have been fiddling with the adjustments to get the thing to make a nice tight joint, and I noticed that I had a gap in the Joint that I could not get rid of. So I took a square to the jig, and checked the top horizontal clamping surface to the vertical clamping surface, and they were not close to square! the angle actually looks like ~ 1/4" out of square in 5" . Is this normal/ by design ?!
Re: Porter cable omnijig tuning
Terry Quiram, Roanoke Illinois
>Evan
I hope I am not going to rain on your parade but I had an Omni 24" dovetail machine that I could never get adjusted. I lost count of the number of times I went through the process of setting it up. My problem was I could get one side right but the other side was off. When I adjusted the off side to fit the first side went out. It was extremely frustrating. I finally sold the danged thing. I hope someone has an answer for you.
Terry
Evan McCarthy
>Sorry everyone, I found the answer, this angle is adjustable, and I just hadn't seen it in the manual.
(very cool, I am quite relieved)
Dick Coers
>You guys are probably talking about two different generations of machines. Terry, you had the old cast aluminum version, the new generation has been named omnijig, but a whole new beast.
All these type fixtures are problematic as far as I'm concerned. Any time the stock you are cutting becomes part of the fixture, you are going to have a problem. When the stock is cupped, or any variation from one piece to another in thickness, the top comb will sit on this bad stock and be further away from the lower piece of stock that is clamped to the front. In this fixture that changes the fit of the joint.
Keller is the only way to go!!!
