old craftsman ras
old craftsman ras
old craftsman ras
JerryBurns
>My nieghbor just gave me a 10" radial arm saw. It is an old craftsman
it is missing the guards and has a drill chuck mounted on the right side. The saw arbor is on the left.It is on a base and runs model # is 11329430.Any idea were I can get a parts manuel. Yes it still runs needs some tlc to go to work. But a farmer I know wants one for cutting up skids so I might horse trade him for ?
Re: old craftsman ras
>I have one that is about 42 or 43 years old. I was not able to read the serial number without moving he saw, but on the front it says "Radial 100". I bought it new when I was about 16 or 17 years old.
RAS tend to be the saw everyone loves to hate or hates to admit they like theirs.
Mine and most of what Sears sold at that time were made by Emerson Electric. Try Googling them for a recall. I have the site bookmarked somewhere and if you can't find it, I can, with a bit of trouble. They claim they will send you newer better guards if your saw is in the recall. Take a whack at it.
I like mine for breaking down lumber and use it often.
Lee Gordon
Re: old craftsman ras *LINK*
Lee Gordon
>That model number indicates it was made by Emerson Tool and thus may be eligible for the blade guard recall. If it is, Emerson will send you a new blade guard, a new 3-piece MDF table top and the necessary mounting hardware. If it isn't one of the qualifying models, they may offer you $100 to send them the motor assembly to permanently remove the tool from service.
You can go to the link below or call Emerson at 1-800-511-2628 for info.
http://www.radialarmsawrecall.com
Or find a use that doesn't require a guard...
Dave Bair, Eaton Rapids, MI
>That drill chuck will let you use the RAS as a primo sanding center. Just insert a spindle sander and tighten the key. You can vary the angle from vertical to horizontal or anywhere in between, including compound angles.
>I remember that recall. I bought my RAS in 1972 and the only option the recall gave me was to give up the saw in exchange for $100. No way - the saw was worth more than that to me. But is the old guard inherently unsafe? In their words, the newer guard "does not require as much action on the part of the saw operator to achieve protection." I chose instead to keep the saw and as operator, take appropriate actions to achieve protection.
BTW, the drill chuck on a RAS is the best way I know to drill a precise hole in the end of a long piece of stock.
You can also get a sanding drum that attaches directly to the motor shaft. I used one for years before I got an oscillating sander.
>JerryBurns,
You can get parts from Sears (link below) without having the manual or parts list. Enter your model number in the box. You can see the parts lists and diagrams. Unfortunately, a lot of parts have been discontinued and the cost of others may not be worth it for an old saw.
http://www.searspartsdirect.com
Charley
>You can try searching on www.owwm.com for copies of manuals and other information regarding your saw if you can't get anything from Sears or Emerson. OWWM.com is fast becoming a major repository of information on old woodworking machinery.
My Craftsman RAS is an early 80's model and I got the upgrade from Emerson, which basically included a new blade guard that lifts when you squeeze the handle and a new 3 piece MDF table. The guard bottoms out on the table behind the fence, which keeps the blade from moving forward on it's own. The cover also shields the blade better while it's in use. I don't use it much, but it still has a place in my shop and is still worth more to me than the $100 they offered as the alternative in the recall.
Charley
