plywood in a desk
plywood in a desk
plywood in a desk
Jarred
>I am building a simple painted desk for my son. the legs will be joined to the apron with mortise and tenon joinery. Is it acceptable to use plywood for the stretchers?
Re: plywood in a desk
Dale Lenz
Dale Lenz
>Don't see a problem w/ plywood for a painted item. Obviously, I'd use a good grade of plywood, like maybe Baltic birch plywood, to ovoid voids, : ' >. OTOH, never have made tendons on plywood, might try making some first on some scrap.
Ned Bulken
>Ultimately it is up to you the builder what is acceptable or not. And to the end user/client/customer, are they going to notice it or not?
>The problem is getting quality veneer core plywood. That's not something you can pick up at the BORG. I've used plywood to check the depth of cuts for router bits and to see what a profile looks like. You always seem to get voids where you least expect them.
My preference would be to use an inexpensive wood such as poplar. Check your local lumber dealers (NOT Lowes or Home Depot) and see what inexpensive hardwoods are available. Poplar typically runs for under $2.00/board foot around here.
>Good Afternoon Jarred,
Stretchers tend to be victims of unattentive, absent minded and oversized feet--especially in a desk where the focus is on the work. I think you may be asking a lot of plywood. I raised 7 sons, and I would use oak or ash. In the amount you need to make stretchers, comparitive costs should be very favorable. Give them an extra coat of paint or two.
George
