Spray on polyurethane
Dan MItchell
>Is there an especially good brand of spray on polyurethane? Tried Olympic water based satin, didn't care for it too much.
Dan
Dan MItchell
Dan
Re: Spray on polyurethane
Larry Clinton At Frankfort (Central)., Indiana
>I have used the Minwax oil base poly - thinned it down 25-50% with thinner and sprayed it with my Binks auto paint gun. It sprayed quite well. I have sprayed it on a couple of doors and to pre-finish some knotty pine I used in one bathroom.
Dan MItchell
>Thanks for that. I should have been more specific, I was looking for a decent spray can variety. I do have a couple spray guns, but haven't used them since my old 240v compressor rusted its tank out & I replaced it with a small pancake type.
Especially looking for the kind with a fan pattern nozzle you can adjust horizontally/vertically.
Dan
I've tried . . .
steve mackay
>Verathane and MinWax sprays also. Didn't think much of either really. Either the nozzels gum up or the finnish just looks "funny".
Re: I've tried . . .
Chuck in ND
>I've used both MinWax and Varathane, I like them both, the Varathane seems like it's thicker.
Spraying poly -- some tips
>Dan, let me know if you find a good polyurethane in a spray can. I'd probably find some uses for it. But for furniture and bigger stuff, I think a spray gun is the way to go. Most guns have adjustable fan direction and size; I'm surprised your Binks gun doesn't. And you can easily spray with a pancake compressor, so don't let that stop you.
One thing about spraying varnishes: they can really gum up the equipment, so you need to flush your gun out thoroughly as soon as possible after spraying. Also, they can gum up your nose and lungs, so wear a good mask, preferably one rated for organic vapors. Another thing: since varnish takes a long time to dry compared to lacquer, be careful how much finish you spray on vertical surfaces in particular; thinned varnish will run and sag a lot. For the same reason, keep your drying room as dust-free as possible. I used to rig up a clean sheet of plywood or other panel material over the finished piece to keep airborne dust from landing on the wet varnish. It works surprisingly well.
Ellis Walentine, Host
Howard Acheson
>Spray can polyurethane is highly thinned so that it can spray well with low pressure. This means it takes lots of coats to get a protective film thickness. Spray can poly is OK for small boxes and such but is a big waste of money for anything larger.
Dave Bair, Eaton Rapids, MI
>Minwax semigloss. The surface was just a little pebbly, perhaps due to my application technique. It seemed to dry pretty quickly. It doesn't quite match Minwax's brush-on version in terms of gloss, so it's probably not a mix and match proposition.
