Plunge router problem
Howard in Bethesda
>I�m trying to make 1 � inch deep, � inch diameter round holes in 1 3/4 inch laminated maple bench top using an up cut spiral router bit in a plunge router. When I get about � inches deep the bit grabs and pulls the router the rest of the way jamming the bit in the hole.
I checked the holes to see if there were any voids but there were none.
Any ideas as how to resolve this problem?
Thanks
Howard
Re: Plunge router problem
North of the Border
>Not sure if I understand your problem. Did you make several passes instead of plunging all the way down in one go? Is using a holesaw or forstner bit to drill out a smaller hole first and finish it with the router an option?
Howard in Bethesda
>Yes I first made a � inch dia. hole. When using the � bit I would try to make the cut in about � inch increments coming up to clear the chips after each 1/4 inch cut, but when I got about � inches deep the bit would grab.
waroland
>Are you setting stops on you router or just plunging it in by hand and trying to stop about 1/4" each time?
My take
>Howard, this is a dangerous operation. At the very least, I'd switch to a straight bit and maybe try to clamp the router down or otherwise anchor it. Up-spirals naturally want to grab, and I think you're lucky you got 3/4" into maple without that happening. The springs in a plunge router's posts aren't strong enough to resist this kind of force. You'd need a rack and pinion to feed the bit slowly enough. A catch can be a very sudden and surprising thing, and you could run into serious, if not dangerous complications, not least of which is mangling your bench top. You might get away with it if you use a straight-flute bit.
My 2¢,
Ellis Walentine, Host
Howard in Bethesda
>I'm trying to stop it by hand and not using the stops. Does that make a difference?
Howard
Re: Plunge router problem *LINK*
LRSmith in NC
>Glen Huey makes this look like child's play in the video. You might want contact him for suggestions.
Click on "Tools" and scroll down the menu to "Workbench Dog Holes."
Popular Woodworking Video
Lee Schierer - McKean, PA
>I would strongly suggest using the stops so it isn't able to go more than 1/4" at a time into the hole. Even so, you are likely to bind in the hole and have some problems as most plunge routers cock slightly as they are plunged and that is a lot of wood to remove all at once with a 3/4" dia. bit. This seems like a case of the wrong tool for the job.
A 3/4" Forstner bit in a drill press would make this child's play. You can even start the holes with a 3/4" spade bit in your hand drill and switch to a forstner bit after teh holes are an inch or so deep and still end up with flat bottom holes or nearly so.
Or make your pilot hole and enlarge it with a 3/8" up spiral bit and a template to get to your 3/4" dia.
Lee
>I had to make some shallow but large diameter round bottom holes for a jewelery box. I used a core box bit about 1 1/2" in diameter. Until I rigged up a method to hold the router tightly it ruined the wood and nearly killed me. I made a frame that had a bunch of strips and blocks in it so I could rearrange them and move the router around in a grid pattern. It worked well.
Either use a pattern the way Glen Huey did or some arrangement that captures the base of the router and does not allow it to move once it is put in place. It is the router "rattling" around and allowing the bit to chatter that is missing you up. I also wonder if predilling the holes is not a bad idea. If you "pilot" hole is even slightly misaligned it might cause the upcut bit to chatter. I would do it without predilling.
Jim Dillon
>Howard,
As Ellis said, this is a dangerous procedure as you are doing it. If you really want to use the router, you MUST find a way to clamp the router down so it CANNOT move in any direction. Once that is done, I would not drill a 1/2 inch prehole, but simply let the router drill its own 3/4 inch hole. The analogy here is using a brad point drill of one size, then trying to enlarge the hole with a bigger drill bit; it doesn't work very well and certainly not in a handheld drill 8-). And, as others have said, really take advantage of those "steps" on your router to control the depth of each plunge. And lastly, using an UPCUT spiral bit, especially one 3/4 inch in diameter, is asking for trouble. In a way, the bit is acting like an auger drill bit and trying to dig itself into the wood. While one can get by with that in smaller diameters (and perhaps softer wood), you have a pretty big chunk of metal spinning around. Of coarse, using a clamped template or drill press are alternatives that might be better in your case. My 2 cents.
Jim
Welcome to TORQUEVILLE!
Art Silva
Maybe a solution
Andrew F in Australia
>I haven't looked through the replies in detail, Howard, but it's either the swarf jamming in the bit, or self-feeding.
I'd go as far as you can with the router bit, then finish it off with a brace and bit - the sides of the bit will keep the hole aligned without chewing it out badly.
Cheers,
Andrew
