building a team box
building a team box
building a team box
mike@american sycamore
>I am building a production steam box to steam bowed arms for Morris chairs. The arms are quatersawn white oak 42" long 6" wide and
1 1/8th" thick. My steam box I made from plywood has de-laminated and the one I built from plastic heavey duty sewer pipe is slowly melting.
My plan is to build a metal box 15" wide 8" tall and 48" long. One end welded closed and a door on the other end inorder to load the box with two pieces at a time.
I will also weld up a water tank 4"tall 15" wide and 48" long to fit 8" under the steam chamber. I will have two pipes running from the water tank to the steam chamber to carry the steam to the chamber.
I have found a manufature of commercial hot plates that will boil the water to 220 degrees for 1 hour and 10 minutes. I plan on adding a temperature gauge and a pressure gauge to help monitor the bend. I have bent dozens of sets of arms with no problems but I want a quicker more professional looking machine. Going electric and not gas will allow me to take this steambox to woodworking shows and do bending seminars and demonstrations.
My main concern is: Will the metal steam chamber create any rust or corrosion problems to the wood?
Any experience from anyone using metal?
thanks,
Mike
Re: building a team box
Dale Lenz
Dale Lenz
>Don't use iron metal with the oak, will blacken the oak. Stainless steel should be ideal.
Dale ?
>Do you think I could use stainless for the steam canber and regular metal for the water tank?
thanks,
Mike
Paul Kramer
Corrosion
Paul Kramer
>Mike,
I think that the tannins might leach from the wood and end up causing corrosion in the tank. That might shorten the life of the tank. As long as only steam is leaving the tank and no iron oxides there should be no effect on the wood. Please remember that chemistry and physics were a long time ago and I might be completely off.
HTH,
Paul
Use Stainless throughout
Ray Thompson - Middletown,IN
>Since you want to make somewhat portable for shows that means filling and dumping a fair amount. Each time you empty it there will be enough moisture to cause some rust, then when you fill it again the rust will flow through the system, and, it will be inconsistent from one time to another. Differences in the amount of residual water and the humidity during storage and travel will cause a different amount of rust each time probably. You are setting yourself up for a problem. Besides the stainless will stay looking good for a very long time, a nice advertisement for you.
Ray
Re: Use Stainless throughout
>thanks for some great feed back......I am meeing with a fabricator in the morning and we will go with stainless through out......hoping I can afford it?
t6hanks,
Mike
Moses Yoder
Re: steam box
Moses Yoder
>I am wondering if the comments on the steel affecting the oak are from actual experience or something that was read somewhere. My knowledge on steam is limited but I do not think it would hold enough metal to affect the wood at all. Other option besides stainless would be aluminum and copper; I have used an aluminum pressure cooker for my water pot for years.
A couple of things in your comments
Keith Newton, LR, Arkansas------WebKitFormBoundary
>The steaming is not so much about getting the wood wet, as much as getting the wood up to 212� all of the way through the middle. The wood and plastics are pretty good insulating material compared to metal.
A new metal one will be a better conductor of heat, which will need more insulation to keep the heat in where you want it. Also the thicker you make it, the more energy BTU"s will be needed to bring that volume of metal up to that target temperature along with the wood.
If I were to go with metal, I would go with the thinnest SS, and have a sheet-metal shop bend it. Then use a more rigid insulating board for structure.
Back to the plastic that you are using. Is it melting from the steam, or is your heat-source and boiler located under the pipe? If so, the heat from the flame getting around boiler may be more the cause for the melting.
I think there may be a lot of misunderstanding about getting the steam from the boiler into the chamber, due to the first simple set-ups that we all saw of a Jerry-can over a fire with the spout going right into the bottom of the chamber. A lot of people seem to think that it needs to be a large pipe to carry the steam from tank to chamber.
Mine is aluminum canning pressure cooker, with about 4' of 1/4" copper tube with foam insulation into either wood or plastic chambers. Although I plan to change that to 1/2" auto heater hose for more flexibility. But that also needs to be insulated to keep from loosing any heat along its length. I wrap the chambers with about five turns of 1/8" packing foam that i have a big roll of.
My PVC and fiberglass pipe needs a board under them for support to keep from sagging. Other than that, I like their other properties.
Joseph Mulherin, Sr
>Mike, I have tried several times to email you a floppy article I have on hand concerning the steam box equipment setup used my Mike Dunbar of the Windsor Institute. Seems your email address is not recognized by the Network. Pictures are included.
Email me at joeirish72@aol.com and I shall return trhe message with the floppy info so you can see and possibly setup your own using his ideas.
Joseph Mulherin, Sr
>For all that are wondering what is in my first posting....here it is about steam box building.
Joseph Mulherin, Sr
>sorry, didn't work.
Dan Donaldson
>How did you enter the picture address to post? Looking at the message, it should have worked. If you want to send me the picture via e-mail, I will put it up for you and try to see why it did not work for you.
Joseph Mulherin, Sr
>Thanks, Dan, but I sent the message and specs to Mike thru another system and I do believe he got them. At my age things do not seem to work as I learned years ago....today's systems are mystifying anymore.
