THE WOODRAT IS BACK!
Gluing question
Gluing question
Gluing question
Tom Pilsbury (Chicago)
>According to the instructions on the glue container (Titebond II) you only have to clamp a glue up for 30 minutes. I've always left the clamps on for at least several hours. Does anybody remove their clamps after only a half hour? I hate to think I'm wasting shop time when I don't have to.
Re: Gluing question
Re: Gluing question
North of the Border
>30 mins is all that is needed, as long as the joint is left unstressed after the clamps are removed and is left as such for 24 hours or so. I never have had any problems with glued joints only clamped for half an hour or so. For small boxes, I've done that for even less than 30 minutes.
Re: Gluing question
Re: Gluing question
Jesse Cloud
>30 minutes is all you need.
I take classes in woodworking at a local community college. Some of us were skeptical when the teacher said to take the clamps off after 30 minutes. The teacher edge glued two boards and clamped them for 30 minutes, then took a hammer to the glue line. The glue line held and the wood ripped about 1/2 inch away.
Having said that, for bent laminations or other glueups under stress, I would leave it clamped overnight.
Re: Gluing question
Agree With Jesse
>Good Evening Tom,
Most times I let the glue "cook" for longer because time is not my ememy. Indeed, you can release the pressure earlier and have a fine glue up. Thirty minutes is okay in my experience. I don't want to rush. There are other processes I can address while the time passes. No need to hurry.
George
Re: Gluing question
Re: Gluing question
>Well that certainly is good news. No more wasted time for me. Thanks all! (Now if I can only conquer this procrastination problem.)
Re: Gluing question
Moses Yoder
Re: Gluing question
Moses Yoder
>You are not saving any time by taking the clamps off sooner, other than perhaps you need the clamps for the next glue-up. The glued assembly should set for 8 hours or so before the glue line is planed off anyway, otherwise the glue can shrink and the glue line will be revealed after finish is applied. I see this all the time on peices at my day job; I guess most paying customers don't know the difference.
Re: Gluing question
depends
Bill Tindall, E.TN
>Under good conditions I have removed panels from clamps in 1/2 hour. Higher moisture content of the lumber and colder temperatures slow set time. I think it prudent to not stress the joint after only 30 min though. If the joint was not perfect any thicker glue line will take longer.
