Tambourette Table, Part III - Finished, (Pics) *LINK*
Jim Shaver Oakville, Ontario
>Hi All,
Well I am done, the table is now finished. I last posted the update of the fitting of the parts and dry assembly, see the link below.
This post is about the glue up and finishing of the table.
The glue up process was very simple, the rabbet joint down the centre easily glued, I did pin it with two brads, one at the top, one at the base.
I followed a finishing process found on Jeff Jewitt�s web site for a Mission dye- glazed finish
http://www.homesteadfinishing.com/htdocs/articles.htm
I used Trans-tint medium brown for the colour, mixed with water and applied carefully by hand , keeping a wet edge moving across the work.
I then used a single coat of General Sealcoat to seal the dyed surface.
The next step was to apply a gel stain that would be the glaze over the seal coat, highlighting the texture and grain in the white oak.
Finally I applied 3 satin clear coats, scuff sanded between coats (320 grit) and then waxed.
Here is the finished table.
The finished work has a 16� diameter top and stands 26� tall. This makes a great lamp stand or a display stand.
Tomorrow I will taking this table to a friend as a gift, she underwent breast cancer surgery this week and starts radiation Monday. She is fine but it�s been a difficult few weeks.
I enjoyed this simple project, I learnt a few things along the way that I would say were well worth the effort. I also hope you have enjoyed my documented process and found it helpful in understanding somethings you may not have known about before.
Take care,
Jim
Part II
