Somewhat OT, Cuttng rafters Question
>It's been a long time since I cut rafters. I have no trouble with the simple ones, but could someone explain to me about hip and jack rafters? About 3/12 pitch.
Anybody got a good internet site that explains this? I have a book on the steel square, but I think my brain is taking the day off. I would like a good tutorial if possible. TIA
Re: Somewhat OT, Cuttng rafters Question
Fred Davis
>Short of watching a carpenter do it , I can't imagine learning cutting and stacking of roof frames from a video. but here are the basics.
For your 3 in 12 roof pitch , the commons are cut either with a framing square set at 3 on the tongue and 12 on the body using framing square clamps ofr ease of repeatibility, or using a saw protaractor set at 14 degrees which is easier , more accurate and the way I do it.
Using 3 on the tongue and 17 on the body , you get the plumb cut for the hip and valley jacks. Setting your skilsaw at 45 degrees gives you the cheek cut.
Each jack rafter spaced on 24 " centers is 2'3/4" longer for the next jack , using the first measurement as the shortest Jack.
So , using this spacing, the second jack is 4'1-1/2" long and so on.
Tell me the building width and I can tell you the length of the common and hip rafters.
FredD
>Thanks Fred. I really apreceiate the help. As my kids say, I used to be able to do this, back in the day. I have not cut hip and jack rafters for thirty years, so to say a "little rusty" is an understatement.
I don't have trouble with the common ones, just the hips and jacks.
I remember the 3 in 17 part.
Does setting he saw to forty five work as it should. I was thinking it was not actually fotry five but some projection of it.
I am working on adding a wrap around porch to an old house. The porch is aobut 8 feet wide. Still working on whether to tie directly to the rafter tails or go up on top of the main roof. One idea is to use T1-11 for sheeting and turn it face down and let the rafters show on the bottom side. That means the nails for the shingles can not penetrate and that my framing must be "neat" or at least prettier than it would have to be if I could cover it with a ceiling.
Where did you get the 2' 2/4"? Since I don't have the exact slope yet, I doubt it will be exactly 3 in 12.
>PS, The pitch is 4/12
Re: Exposed roof decking
Kneale Brownson dreaming of snow in N. MI
>If you put your ply down and then top it with some OSB, your roofing nails should be hidden.
Fred Davis
>I got the angle from your first mesage , now since the roof slope is 4 and 12 the shortest jack for 24" spacing, will be : 2 foot , one and a quarter inch . 25 1/4 "
The angle on a saw protractor for the ridge, hip and valley cut is 18 1/2 degrees.
The skilsaw is set at 45 degrees becasue a hip or valley bisects a square.
Fredd
Thanks, Fred and Kneal
>Between posts I went and did some measuring and figuring. I will fudge the beam height to make it a 4 in 12. I like that better than 3 in 12. There is a roof above that dumps down onto this and its at least 8 in 12. Don't like the idea of a low pitch below a high pitch, but its what we got.
We will not be able to make the under side of the sheeting exposed, because of the way the roof and over hang on the original house is framed. Iaqm actuly pretty happy aobt that. A ceiling may overa multitude of sins.
Thanks for the help.
Re: Thanks, Fred and Kneal
Fred Davis
>Barry ,
without beating this subject to death I meant to tell you what the terms pitch of the roof and slope of the roof means.
The slope which you are struggling with is determined by the rise in inches of a foot of run. So the 4 in 12 means it rises four inches for every foot of level span run.
Pitch of the roof is determined by dividing the rise , in this case four into the whole number 24. The result is then called a one-sixth pitch.
About the exposed T1-11 sheathing, if it is 5/8ths thick which is a standard thickness for it, then you should have no trouble nailing down three tab shingles of at least 240 lb. a square with 3/4" long roofing nails without getting any shiners.
FredD
