Inlay Bushing
Keoni
>Do the router inlay bushings that fit Porter Cable, Blach & Decker fit Ryobi routers and laminate trimmers also?
Inlay Bushing
Keoni
Re: Inlay Bushing
Lee Schierer - McKean, PA
>The inlay bushings are an exact fit to Freud router template bushings. If the routers you mentioned accept the Freud template bushings the inlay bushing shouold also work.
Lee
A non-answer
>Most router brands accept the industry-standard PC template bushings. Some brands have larger holes in the router baseplate to accommodate bigger bits like panel raisers, etc. Most of these provide a base insert plate that accepts the PC bushings. One exception is Bosch, which has its own proprietary style of bayonet mount bushings -- or used to. If I were a betting man, I'd say the odds are very good you can use standard bushings in your Ryobi routers, but don't take my word for it.
Ellis Walentine, HOst
