My Limbert Tabourette, A Work In Progress Part II *LINK*
Jim Shaver - Oakville, Ont
>Hi All,
Well here is Part II on my Limbert Tambourette table. This is a fun project and I enjoying documentation my process for you to red.
Last we spoke the table was in a roughed out condition, the legs were laid out and cut at the bandsaw and the top was cut as well.
My next step was to use a pattern bit at the router table and use the leg template to route out 4 identical legs.
It had been awhile since I have used my router table, a few moments spent visualizing the cuts and the direction of feed vs. potential grain conflicts and off I went. I had rouged out the size to the template on the generous side of extra wood, so I used progressing sized bearings to make the cuts till I was comfortable to go to the net bearing size for the final cut.
Quite a difference from the roughed out look, the routed shapes have a final look. Despite the routed sizing being close to final I still used some rasps and spoke shave work to get the ready to finish surfaces I wanted.
Once I had the legs dry fitted I was able to now measure up for the slot cuts on the lower shelf.
I used a table saw set up to get centered slots and some fret saw cuts and final chisel work cleaned it up nicely.
I sized my shelf stock thickness a hair more that the slot in the legs, so for a clean crisp fit I planed down the over all shelf thickness till I got that custom fit.
I used a small can of wax to lay our the corner radius and cut them clean at the band saw, some final rasp work and a quick light sanding and they were done.
So here it is, all dry fit, all hand planed and ready for glue up then a finish
Everything is coming together well, I have a few things I would do differently next time at the router table, but I have been flying through this project quickly.
Stay tuned, I have a feeling it will be ready really soon for final presentation,
Take care,
Jim
Previous Post, Part I
