Poly compatibility question
Nat Robison
>I'm refinishing the floors in my house and I've used a less-expensive WB Poly for the first 2 coats. I'd like to use a slightly more expensive Varathane WB Poly for the last 2 coats.
Any compatibility problems that anyone can foresee? Also, if I have to stretch the gallon of Varathane, can I mix in some of the less-expensive poly (as long as I don't do it mid-coat)?
I haven't used WB Poly (and would probably choose oil-based if there were no other considerations) on a floor before but the ability to do 2 coats in a day coupled with a spouse who has an abnormally low tolerance for household projects swayed me.
