Re: painting concrete floor
Fred Davis
>I used Porter Paint two part epoxy on my garage floor , I think probably any major brand will do the trick when the floor is ready.
If you did not spray the concrete after troweling with a curing compound then the water in the concrete is still evaporating and will for sometime longer then four weeks. This will interfere with adhesion if to much water is present .
You can test for this by taping a small square of clear plastic to the floor . I
If you see water forming like sweat under the plastic, then it needs to cure longer.
A large barn fan blowing across it will speed it up and you can rent these if you don't want to buy one.
About the surface of the paint after it dries, if you apply it with a roller , it will texture paint with tiny pimples that makes a great nonskid floor covering.
FredD
