Delta D J 20 jointer
Fred Davis
>I traded in my old Boice-Crane Jointer about eight years ago and bot a Delta 8 inch DJ 20.
The dealer set it up and it worked just fine until yesterday when it started putting tapers on edge joints.
So naturally I got out the manual that came with it and even though it is printed in several languages, there was not a clue how to adjust it .
After three phone calls , I got a woman who said .... we have a five page fix for it that was left out of the manual and you aren't the only one to wonder what gives.
So she sent me the info in a email , got it three minutes later and looked at it and said......never happen , I am to happy now to spoil my day, so I waiting for a mechanic who the dealer uses in this part of the woods to set this machine up.
Anybody that has that machine and wants the information that was left out of the manual , I will send it to you.
FredD
Re: Delta D J 20 jointer
Curious question
Mark Goodall - ATL- tool junkie
>When I bought my DJ20 about 10 years ago, I too discovered there was a section of the manual that was "missing".
There was a fax circulating that contained a few pages of additional information. I placed it on my website way back then. The information in that fax was not laid out in easiest/best way, so I started to make it more readable/understandable. I never got around to replacing the diagram with photos or finishing it.
I'd be curious if this missing part of the manual that they sent you was the same thing that they sent me 10 years ago.
Could you send me a copy of what they sent you?
Thanks.
Happy Woodworking!
Jesper, Denmark
Jesper, Denmark
>Me too, please.
Thanks.
Howard Norman
>Yes, I would like the information on the DJ-20 jointer.
Howard
I would also like the info
Dan MItchell
>Thank you in advance.
Dan
Sue McLam in Orange, VT
>Fred,
Please send me the info too. Thanks!
Sue
Allan A Campbell
>Fred,
Me Too?
Thanks,
Allan
Re: I'd appreciate a copy, please.
Al Stokka - Cambridge, Iowa
Bart Goldberg
Bart Goldberg
>Hi Fred, Please send me a copy as well.
Please remove the "2" from my listed address before mailing.
Regards
Bart
Kris Lasure
>Why you're at it, please pass one this way.
Thanks!
James Purciful
James Purciful
>I'd like a copy as well please.
It's odd that they didn't just post it on their website somewhere...
Re: Curious question
Fred Davis
>Check your mail Mark.
FredD
Joe in Tallahassee FLA
>I would appreciate a copy too, Fred. Mine has not exhibited this problem but I am about to change the blades for the first time and would like to be prepared.
Thanks in advance.
Joe
THANK YOU, FRED!
Kris Lasure
Re: Please add me to the list.
Kneale Brownson dreaming of snow in N. MI
Thank You Mark
Jerry White
>Mark,
When I first got my DJ-20 a few years ago I remembered that I had seen this information on your very informative website and I downloaded it. It turned out that I had to do quite a bit of initial adjustment on my machine and your information was invaluable. I just want to extend a belated "Thank You".
Jerry
Jordan
>i would greatly appreciate a copy as well..thanks in advance :)
Mark Lepore
>Would you please email me it also.
Thanks in advance,
Mark
please send jointer info please NM
Jordan
Re: please send jointer info please NM
Fred Davis
>DID,TWICE
FredD
Jordan
>email sent...thanks !!!!!
Rick L
Re: Parallelgram adjustment PDF *LINK*
Rick L
>It's a basic intuitive procedure for people who work on machines like myself. You do need a straightedge, a machined one is better but a good level or floor installers straight edge one will work. Most folks jump the gun on their jointer needing this adjustment when it's typically the cutters being dull or set wrong. Incidentally I do this kind of work in the western Mass area. I have a 6' precision straight edge and have done quite a few paralellogram jointers over 25 years, up to 16" SCMI's and such. I can do a 8" DJ-20 in an hour or so.
Paralelogram adjustment PDF
Fred Davis
>The jointer is out of adjustment because at least one infeed table eccentric roller moved and because the outfeed table is set at twenty thousandths over the cutter head instead of ten.
The knives are razor sharp, my basic intuitive response to this readily apparent situation is simply call the people who sold it to me and naturally being the good guys they are , will be up this week to adjust it.
I can do some things really quick, this isn't one of them.
FredD
Re: So, Fred.....
>Is the PDF in the link here what you were attempting to email/fax?
Rick L
Re: It coudn't be anything other...
Rick L
