Lighting Height In New Shop
howard
>Finished ceiling height is 10', and I will be using 8' 2bulb flourescent fixtures. Would you attach them directly to the ceiling, or is this too high. Appreciate all comments on what you have done.
thanks
howard
thanks
Re: Lighting Height In New Shop
>I don't like the 8' fixtures. It's difficult to get good "colors" in the bulbs (unless you look really hard). They usually don't have diffuser panels that are readily available either.
That being said, you can hang them directly on the ceiling or let them come down a bit (maybe ~9'). I would suggest task lighting of some variety for work areas (workbench, lathe, drill press, band saw, table saw, etc.). I've got track lighting over my workbench and lathe - I wouldn't be without it.
David Yoho
>It depends on how much you swing long boards around in your shop. My first shop had a ten-foot ceiling and I used four-foot florescent fixtures hanging about a foot lower. Whenever I bumped one of them while maneuvering lumber, they moved and no bulbs got broken. My current shop has a ceiling height a little over nine feet. There are four eight-foot fixtures mounted to the ceiling and five four-footers hanging about a foot lower. The smaller fixtures are all over benches or non-movable tools. I still bump the eight footers once in a while when handling full sized sheet goods on end.
David
Bill Tindall, E.TN
>Iight intensity lessens by the square of the distance from the source. Hence, there will be significantly less light "on the bench" if the lights are at 10' vs 7 or 8'. It is easy to hang lighting from chains. The lights over my bench are only at 7' to enable me to get the 200cp I wanted for fine work.
I agre on the 8' fixtures
Bill Tindall, E.TN
>I took them out of my last shop and replaced with 4' for reasons stated.
Fred Davis
>If you haven't purchased your light fixtures , give a thought to HO (high output) florescent , you can get it in 120v. or 240v.
Costs a little more initially , but the light output will please you.
On height I read a learned article on height well after I had installed 4 rows of double tube strip lights, each eight feet long and the opinion was , seven feet above the work surface was the ideal height.
That being said , in my shop the ceiling rises from a ten foot side wall to about 14 feet , the light fixtures are at about nine feet for two rows and twelve feet for two rows.
The overall light level is even , over the workbench and RAS and some other stationary tools , lower fixture is used.
Keeping the light tubes clean helps a lot in maintaining a good light level, the tubes decline over their estimated 5,000 hour life and if you wait , like most to replace them as they burn out , you will eventually end up with considerable less light then you started out with.
The one thing I can't seem to do anything about is the eyesight not being what it used to be.
FredD
Thanks Everyone.................
howard
>great suggestions, I think what I'll do is mount some fixtures at the 10' height in the center of the shop, but place 4' fixtures lower around the perimeter where the benches will be, etc. This will also keep the lower fixtures from being hit by long lumber. thanks again.
Fred Davis
>make that eleven and twelve feet high respectively
FredD
