Food/Allergy issues with a Walnut countertop
Alan Young
Alan Young
>I have a potential project lining up. Client wants a Walnut top for an island. What sort of issue could there be with this regarding allergies etc? Is a finish in Waterlox likely to keep the hives at Bay?
Thanks for any insight...
Alan
Re: Food/Allergy issues with a Walnut countertop
Re: They aren't going to eat the countertop!
>So it's not likely that they would get enough of a concentration of juglone to do anything. A good finish (such as Waterlox) would prevent any migration.
David Yoho
>Alan, while I love and use Waterlox anytime I can, I'm not thinking this is the right finish for the intended use. I think your customer will be safe with the walnut as long as it's finished (they won't be eating it anyway).
I think you'll need to deal with filling the pores first and a polyurethane finish would be a better choice.
David
Dale Lenz
Re: Spar Varnish?
Dale Lenz
>Treat them to walnut ice cream and see if they have problems, : ' >.
Does the client plan to.........
Howard Acheson
>.....prepare food on the countertop? Does he plan to cut and chop, put hot dishes or pots on the surface?
If the surface will be used for food preparation, you do not want to use a film finish. Knives and such will cut through the film, water and food juices will get under the surface and the finish will quickly fail. In addition the cuts will promote stains and make it impossible to clean completely. Also, walnut is not a very hard wood and does not work well for heavy use countertops.
While I am not a fan of wood countertops in kitchens, if you go down that road, I would use the same type of surface treatment as you would on a cutting board or butcher block.
An excellent treatment for cutting boards and butcher blocks is a mixture of mineral oil and either paraffin or beeswax. This is what is used on many commercial wood surfaces. It will last longer and be more protective than just mineral oil. Mineral oil can be found in most supermarkets in the pharmacy section or in a true pharmacy. Paraffin is found in the canning section of the store or in a hardware store.
Heat the oil in a double boiler and shave in some wax. The exact proportions are not critical--a 5-6 parts of oil to one part of wax will work fine. Stir the mixture until all the wax is liquified. Apply the mixture heavily and let it set 10-12 hours or overnight. Next day do it again and continue until the wood will no long absorb the finish. Let it set for 10-12 hours and then lightly scrape off any excess. Then buff it with a rag.
Reapply whenever the wood begins to look dry.
Alan Young
Re: Does the client plan to.........
Alan Young
>Howard thanks for your response...The client is requesting this- at least as far as my involvement in the project goes. If she goes with a corian or cement or other such top I'll be out of the loop..
.....Does the client plan to prepare food on the countertop? Does he plan to cut and chop, put hot dishes or pots on the surface?
I am ascertaining those specifics answers....generally food prep at least...
That is understandable.....But I am wondering...
Is this finish tough enough to with stand the conditions you described as detrimental to a film finish? Oil and wax would seem to have the same tendencies to suffer from knife cuts and the resulting problems you described....perhaps the wax sets harder than I comprehend.
Would a polyurethane as suggested not be a harder finish?...
Alan
Glenn Madsen in the SF Bay Area
>"An excellent treatment for cutting boards and butcher blocks is a mixture of mineral oil and either paraffin or beeswax. This is what is used on many commercial wood surfaces. It will last longer and be more protective than just mineral oil." -Howard
"Is this finish tough enough to with stand the conditions you described as detrimental to a film finish? Oil and wax would seem to have the same tendencies to suffer from knife cuts and the resulting problems you described....perhaps the wax sets harder than I comprehend." - Alan
The oil and wax finish isn't tough in the same way. It gives, and then heals, never forming a film or skin. It's more 'in the wood' than 'over the wood'. I have a maple cutting board purchased 30 years ago that's had maybe three treatments with commercial 'block oil', mineral oil. None in the last 5 years, certainly. It gets washed three to five times a day by hand. It's starting to look 30 years old. In other words, well loved.
If this is a chopping block, then let it be one. If it's a table, then make her a chopping block to put on top of it.
Howard Acheson
No, wax is not harder. The benefit to the wax is that it is an in-the-wood treatment that retains its integrity even when cut or dinged. It is also easy to renew/repair when it's necessary.
Yes, polyurethane varnish is harder than a wax. And, therein lies part of the problem. A harder finish which is an "on-the-wood finish is easily damaged (cracked and crazed)when it is penetrated or dinged. Once penetrated or cracked, it is quickly further damaged when water or other moisture gets under the finish. Also, a film finish is much harder to repair as it required using a chemical paint remover and/or lots of sanding.
