>One of these days I'll find some time to do some woodworking. For now, it's all about fixing things. I have a 6 year old Frigidaire gas dryer that sometimes will not heat. It started a few days ago. Sometimes I can hear the gas ignite, sometimes I can't. I've cleaned out intake and venting, and that's about it. Any ideas before I call a repairman?
>Sounds like a problem wit the ignitor or ignition circuit. There is an interlock on them such that if the ignitor doesn't heat up, the gas won't flow. There should be a cover so that you can see into the heat chamber. When you turn on the dryer, you should see the ignitor get hot and glow just before the gas starts.
>I've had to repair my GE twice now. The first time it was contacts in the timer. It would run around the cycle, but the contact would not be made to light off the ignitor and start the burner. First try a different cycle on the timer, like delicates and see if it lights all the time. Find the cycle that it won't light up on, and flex the wheel on the timer back and forth with everything running. It may light off when pressure is set in one direction or another. I had to replace the timer.
The second incident required replacing the ignitor coil. I took it off once and checked continuity. I'm sure I read it as okay. I put it back in, no light off. I checked the leads into the ignitor as the cycle started. There was current at the ignitor, but it would not glow. Replaced the ignitor, and it's works fine.
