Liquid hide glue - slow to dry
Joe in a Cleveland suburb
>Hi.
I am making a small Shaker table for my daughter. It's basically the one that was in the (I think) first issue of PWW's Woodworking magazine. I'm using walnut.
Yesterday I glued up the top. I used some liquid hide glue I've had for some time now. I put a drop between my fingers and pulled it apart a couple times. It seemed to be okay - got strings between my fingers and it was pretty sticky. I recalled reading that tip someplace to test if the glue was still good.
I did the glue up yesterday morning. In the evening I went to scrape off the excess with a dull razor blade before it got too hard. It was softer than I thought it should be.
This morning I checked it and it still seems a bit soft. It's not hard. I can indent it with my finger nail.
Is this normal? It's is a bit humid/rainy here. Does this affect hide glue's drying ability? Should I wait a day or two before I remove the clamps? Did I just make some more firewood?
Thanks.
Joe
Re: Liquid hide glue - slow to dry
world expert on this adhesive......
Bill Tindall, E.TN
>lives over on the Hand Tool Forum. Ask there.
Re: Liquid hide glue - slow to dry *LINK*
>There is a definite shelf life to liquid hide glue. I don't know how old yours is, but it may be too old.
The humidity can be a factor in slow drying and curing.
You haven't made firewood - after all, you can easily remove liquid (and solid) hide glue with hot water and steam.
Deller's article
Thanks Bill and JL...
>I posted over there.
Bill Tindall, E.TN
>Over on the other side you are looking for a response from S. Shepherd.
1. Test a joint with this glue. Glue up a test piece using a lap joint with. the ends of the two pieces sticking out. After a day, clamp one leg of the lap joint in a vise and bash the other leg sticking up sufficient force to break the joint apart. The wood should fail across most of the joint, certainly 75% or more. If it does not then the adhesive is inadequate for some reason.
2. The first time I used hide glue was to glue two 2 x4 cherry to make a 4" post that I then turned to make a cannon ball bed. The glue failed on some of the joints. I decided then and there that I was not going to use an adhesive that was inherently prone to failure if not "fresh" by some standard. I from then on used what the furniture factories use, yellow glue. You don't need to worry about whether it will work.
Thanks Bill.
