Ideas wanted..............
Richard Jones
>Building a small (36" dia max) table for the grandbabies to sit at and do some art stuff. Want to make it expandable, so need a simple plan for changing out the legs. Thought about turning some, but need an easy on/off attachment method, and must be fairly stable, since I believe they must be direct descendants of Conan the Destroyer......
Thanks, hope everyone has a great day, and please send us some rain.............
Rich in VA
Re: Ideas wanted..............
Bill Tindall, E.TN
>A table with legs mortised into a frame which in turn attaches to the top has proven to hold up over the centuries. If you don't mind making new legs, making the additional new frame is hardly much more effort. But.....I went the same route and we always found a use for the short table with its robust work surface top. It has plants on it now and soon will pass to granddaughter to start all over as a child's table. Keep this possibility in mind as you decide what to do and how well to make it.
Tony - Memphis
>I remember a table my wife owned before we got married that had detachable legs. There were corner brackets that held the rails, and the legs had bolts in them on the corner that bolted to the metal bracket that held the rails. It seemed to be pretty old and felt sturdy, so I assume it was. Might look at Rockler for something like that. You could always make a turned leg that had an insert in the bottom and just add the extensions when it was time.
Tony
Re: Leg Apron Brackets *LINK*
Kneale Brownson dreaming of snow in N. MI
>I've had tables as heavy as a couple hundred pounds that had sturdy legs (big as 3X3") attached with metal brackets something like what came up on my first Google choice:
The more sturdy you want the table, the larger/heavier you want the bracket. This one's from:
Woodworker's Supply
