Edge Gluing
Edge Gluing
Edge Gluing
Kelly Handwerk
>My cable network now get DIY station, so I have been watching David Marks woodworking show. He does a lot of edge gluing with stock under 3/4 of an inch (1/4 and 1/2). I have never edge glued 1/4 material, does this glue up OK?
Re: Edge Gluing
yes
Bill Tindall, E.TN
>I'm a bit confused by the question. What is the concern that thin material would not make a sound joint? Veneer is edge glued, so there is no limit to thinness.
Re: Edge Gluing
Re: yes
Kelly Handwerk
>Yes, that was my concern.
Re: Edge Gluing
Re: yes
Bill Howatt
>If the joint is made properly regarding adequate glue and proper clamping, the resulting joint is often stronger than the wood.
Bill
Re: Edge Gluing
Re: yes _ I'd have thought
North of the Border
>your concern should be the opposite: glue alone may not be strong enough if the edging is thick and big, in which case we may use additional fasteners such as screws, dowels or biscuits, etc. for extra bonding. May be your concern is about some other aspects of the edging or gluing?
Re: Edge Gluing
By Edge Gluing You mean...
David Yoho
>If you mean edge gluing pieces of stock together as in a solid panel, yes, just glue works fine. As was stated already, even veneer is edge glued. If the edges of your stock are properly jointed, all that is necessary is glue. The only caution to mention is if you're gluing thin (less than 3/8") stock, keep an eye out to make sure the glue-up remains flat once clamped. The wider the panel or the more pieces used or both will influence whether things remain flat when applying clamp pressure.
David
Re: Edge Gluing
Re: By Edge Gluing You mean...
Jesse Cloud
>I agree with David. When we are edge gluing bandsawn veneers, around 1/8 inch thick, we use a shop made jig. The jig consists of a piece of baltic birch larger than the panel you want to glue up. Make two fences out of baltic birch, the width of your first piece and a couple of inches high. Route two parallel through holes across the length of the first piece, leaving about 2 inches on either side. Glue one fence on the edge of the holes. Drill two vertical holes through the other fence so you can run a bolt through the fence and the bottom piece. Use a bolt, washers and a wing nut (or jig handles) to fasten the fence. What you now have is one fixed fence and one adjustable. For convenience put some feet on the jig.
To use it, lay a sheet of wax paper on the jig. Place the pieces (with glue when you are ready) on top of the paper. Slide the fence to about a 1/4 inch from the assembly and tighten. Use pairs of wedges to "clamp" the assembly. To be extra safe, put some wax paper on top and some weights (routers work well) on top of the joints. Your panels will come out nice and flat.
Sorry this went on so long. Hope it helps.
Re: Edge Gluing
Re: By Edge Gluing You mean...****
MikeW
>Here's how I glue up thin bandsawn stock--I think this is similar to what Jesse described.
Here I glued up in pairs and for a couple wider panels, glued the pairs to each other.
If the edges are jointed well, the pairs of wedges will exert more than enough pressure without buckling the join. I use a shooting board to joint thin stock, which helps keep the thin long edges square.
Take care, Mike
