My lacquer finishing process
Dale Lenz
>I've been spraying lacquer for almost two years now. I use SW Cat lacquer. If I'm after a high sheen I do the following on something like cherry, tight grained wood.
Step 1: Put a sealer coat of 1# Seal coat. Thin lacquer about 15%, 85% lacquer, 15% thinner. Shoot four coats of lacquer( 10-15 minutes drying time between coats) wait at least two hours and sand down with 400 grit paper. Not uncommon to rub through the finish at this stage
Step 2: Shoot 4 more coats of lacquer on, wait at least two hours and sand down with 600 grit. Often will not rub through finish.
Step 3: Shoot 2 coats of 40% thinned lacquer, gives me a smooth finish. Wait 2.5 days or longer and work the lacquer by using 800 grit sand paper. Then I use several grits of automotive rubbing compounds with wool bonnet to get to the high sheen.
Question: If I'm not rubbing through the lacquer after step 2, could I not just wait 3 days and start the high sheen process. I have always assumed that Step 3 gives me a little bit of wiggle room, more surface finish, but then again it's more/extra work Maybe(?).
