Re: Dealing with wood movement question..
Rob Hix - King George, VA
>The shrikulator shows a 1" shrinkage when the wood acclimates at 90% relative humidity and is moved into an environment with 30% relative humidity, this is for a 20" wide board. That really surprised me. Anyway those number are a little off track for me. If I go with something a little more like I would see this time of year I would say it acclimated at 85% and moved int 45%. This gives me a shrinkage of just over 1/2" this is what I would plan on.
That being said, I do not know where you live, and you should be looking at conditions that are reasonable for your area. I would think 1/2" shrinkage would be enough to plan on. Also, remember that once it is built and inside the house you will not see a change this big because the relative humidity will not swing that much. Finishing will also have a little effect on it.
If it were me, I think I would make the tray (and finish it) for the table and take it inside and measure the shrinkage. In a couple of weeks or less it will probably stop shrinking. Take measurements and go build the base. The design of the base tells me it will not change size at all. Design for a little leeway, but if you built the base to exact size of the top this time of year you would likely be ok. Thing will only shrink in the winter.
When I build drawers this time of year, I build them as tight as possible for them to still work. Then, they still look and work beautifully in the winter.
I wish you the best of luck,
Rob Hix
