trunk dovetail layout question
Bill Tindall, E.TN
>Because I don't have occasion to do it often, and it needs to be done right the first time, I lay out a dovetail pattern to scale on paper to develop spacing, size and other decisions. I did this for the trunk as I would a drawer, starting with a half pin on the board with tails (which is the trunk front). I think it looks strange.
I have several dozen trunk pictures in books and none clear enough to see this detail. I can see that trunks have tails on the front of the trunk, but I can't tell if the pattern starts with a half pin or a half tail.
So, what is the convention for a trunk? There likely will be no molding to cover either the top or bottom of the front board so this detail will show.
Re: trunk dovetail layout question
David Yoho
>Bill, be it a drawer or a chest, I always start and end the layout with a half-pin for through dovetails. I've found this to be the traditional method but you could always depart from that if you want.
