>I recently helped my son work on his fiance's car. The muffler failed. I broke both botls holding the flange. The remainder of the blots stuck about 3/4" through a nut welded to the flange on the exhaust pipe. I used ViceGrips and got them out, but it took a long time and a lot of elbow grease. On one I could only turn it about a tenth of a turn each time and had to reposition the pliers at least fifty tiems. I am not a car guy. Is there a tool for this?
I was thinking of something that worked like a pin chuck on a lathe. Perhaps a hardened steel nail jambed in a small socket? I got them out, but there had to be an easier way?
>Most muffler shops use a torch to remove the old clamps (if that's what you're describing). There are reverse-drilling extractors that work pretty well. Welding another piece of bolt onto the broken one also works if you have that facility.
>Many times stubborn bolts can be loosened by heating with a torch. I never liked crawling under a car to do exhaust work. It's too hard to get to the work, stuff always falls in your face when beating on old exhaust parts, and you can't get enough torque on a bolt. Try heat or soak it down with a rust cutter or penetrating oil. It usually seems like these things are almost "welded" by the heat and liquid solutions don't do anything to help.
>Barry: from your description, it sounds like you may be working on either a hanger or clamp? Most of the muffler hangers/clamps are easily (and fairly cheaply) replaceable. It sounds to me like you are working on a "throwaway" item. You may want to go to an auto parts store with a photo or description of the part and price a replacement. Most are attached to the car frame or floor with a single bolt - in a location that isn't subject to the extreme exhaust heat - and therefore is easily removed. If you are working on a part that is an integral part of the car, I would heat the part with a propane (or acetylene) torch, then apply a mix of transmission fluid/mineral spirits while it is still hot. (watch out for flames as it will "poof" & burn), continue to apply the mixture till it is remaining wet, then let it set for an hour or so. Normally after a couple of shots of this the bolts will remove without breaking. I have in some cases drilled clear through a broken bolt/flange and replaced the "studs" with through bolts (if there is clearance to do this).
>I had tried heating it with a torch and soaked them over night with PB Blast, but both bolts snapped. I got them out with vice grips, but I was wondereing if there was some trick or tool that would grip the threaded end of the bolt and screw it out.
>If I understand what you're saying, you were trying to remove a frozen bolt by turning the "wrong end" with pliers or vice grips. If enough of the bolt end is exposed, you could try using a Dremel or RotoZip with the small gringing wheel and cut a slot in the end of the bolt shaft and then use a slotted screwdriver to back it out.
