Hose for ROS
Hose for ROS
Hose for ROS
Sawman
>I am looking for a 1"ID hose for my PC ROS sander. The one I have is getting pretty beat up. Any ideas for a source?
Re: Hose for ROS
Re: Hose for ROS
>I have the PC ROS with the 1" port. (Not the newer on with the oval port.) I went to Lowes and bought a hose kit for a small shop vac. The hose is aobut 1" or 1 1/4" and the wand tapers down to where it can be forced onto the dust port. Used a reducer on the other end to fit it to my DC port. I often use the wand as a handle on flat surfaces. Works for me.
Re: Hose for ROS
Hijack concerning the PC "oval port"
Rod Peterson -- Ormond Beach
>I was concerned about that oval port when I got my new PC-ROS six months ago, because I've long had the PC hose to fit my older PC-ROS (we're talking model 333, here). Not to worry—when you pull the dust catcher off that oval port, there's a perfectly round fitting inside which fits the PC hose perfectly.
Rod
Re: Hose for ROS
Re: Hose for ROS
David Yoho
>Sounds like you are looking for a fix other than new. Otherwise - do you have a local PC service center near you? My local center services and sells replacement parts for PC, Delta, DeWalt, and B&D tools.
David
Re: Hose for ROS
Re: Hose for ROS *LINK*
Larry Marker
>Highland Woodworking has the PC 1" 10 foot hose.
Highland Catalog Entry
Re: Hose for ROS
Re: Hose for ROS
Gene Gauss
>I bought a piece of 1" ID hose for my PC ROS from McMaster-Carr (www.mcmaster.com).
Re: Hose for ROS
That's what I did!
Lee Schierer - McKean, PA
>I did the same thing. I found that 3-4 wraps of electrical tape around the outlet of the sander made the hose fit perfectly. I can remove the tape when I wan t to use the origianl dust catcher.
Lee
