Returning A Favor (long)
David Yoho
>About five years ago a fellow I work with stopped by my shop on his way to the dump. An uncle of his had passed away several months before and the family was going through his things in his workshop deciding what to do with all the tools and lumber. After the family took what they wanted, they decided to simply discard the remaining wood and my friend remembered me and thought I should take a look at what he was hauling to the dump before getting rid of it. The back of his pickup was about half full of boards. At first glance, it didn't look like much. A closer inspection revealed some very nice and usable walnut as well as a rough-sawn poplar timber that measured about 8 - 9 inches wide, 6 feet long, and about 4 inches thick, with a split in the center of one face.
I selected all the usable walnut boards I could store along with the poplar timber. The walnut was not pristine but dressing and cutting yielded a good quantity of usable wood. I cut around the split and dressed the poplar into several good-sized pieces for use later on as leg stock. The rest of the walnut was pretty ratty stuff so he hauled it to the dump. Besides, I didn't have space to store any more even if I had wanted to.
About a month ago, we were talking and he asked if I would build him a small table to go in front of a picture window in his living room. He gave me some dimensions, said he liked the arched aprons he'd seen in a picture I showed him of a table Chico made, and left the rest up to me. He wanted mahogany to go with another small table I'd built for him years ago but he was intrigued with the notion of mixing a different species of figured wood with the mahogany. After searching online sources, I finally found a piece of "collector's grade" cherry on Hearne Hardwoods Website. I showed him the picture and he said to buy it. I ordered the cherry and also bought a piece of mahogany from a local supplier. The mahogany was cut from a 14-foot timber. It was 7-ft. long, 6 1/2-inches wide, and about 3 1/2-inches thick - big enough to yield all the parts for the table base.
Then came the subject of money. Knowing what I get for the work I do now days, he voiced some concern about being able to afford this project. I told him that I remembered a fellow bringing me some walnut at no charge one time and as long as he paid for the materials, I was more than happy to return the favor.
Here's a shot of the finished table. It measures 20" tall, and the top is 15 3/4" wide by 40" long. As I did in the top of the previous table, I inlaid a diamond shaped piece of lacewood in the center of each apron. The legs are tapered (first time tapering legs) and the aprons are joined with pegged mortise and tenon joinery. Since my friend likes the natural look of wood, I used Watco oil and wax for the finish. The cherry top, being a tighter grained wood than the mahogany, came out looking like a piece of glass and just as smooth.
Here's a close up of one of the diamond lacewood inlays:
The final shot shows the wonderful grain of the cherry top. The bow tie inlays are from the walnut he brought me. I thought it would be a nice way to incorporate the walnut into this project. The cherry has a very slight curl to it but also a little quilted figure as well. I placed it outside in the sun for about three hours on three different days to darken a little. It doesn't jump out at you at first but viewing it in sunlight at various angles shows off the beauty and subtle figure of this piece of cherry. My friend picked the table up this past Wednesday and to say he was pleased would be an understatement!
Thanks for viewing,
David
Re: Returning A Favor (long)
Beautiful!
Joanne Adler in Pt. Pleasant, PA
>Beautiful story--Beautiful table!
That is one gorgeous piece of cherry. I love how you used the walnut he gave you for the butterflies. And the lacewood inlays in the mahogany look wonderful, as well. Do you cut those inlay pockets by chisel or router? And you know I love that you used just a natural or relatively clear finish. Thanks for posting.
Re: Beautiful!
David Yoho
>Thanks for the kind words, Joanne. This really was a fun and quick project.
I cut them with the router but you still have to clean up corners with a chisel. The tricky part, I think, is making the templates.
I wish I had taken a picture of the cherry top that better showed the glass-like finish I get from the oil and wax. The end result makes all that rubbing worthwhile. The point is - there are still many woodworkers out the that don't think this type of result is possible with that kind of finish.
David
Nice job, David!
>That cherry is really outrageous, and the butterfly keys are a great touch.
Might be a shop shot here... :-)
Re: Wonderful story
Kneale Brownson Dreaming of the Snow in N. MI
>Just curious. I know the cherry will darken forever. I have pieces of a delicate cherry chair my father broke in a fall several years before he died. I've not been able to figure out a way to fix it. The chair was something his wife had saved from her mother's home, so we're talking a piece at least 100 years old now. It's black enough that I'd bet your walnut inlays would be difficult to see. Will that happen eventually to your table?
Re: Beautiful work David
Larry Clinton At Frankfort (Central)., Indiana
>The table is stunning - graceful design and beautiful wood. Makes you feel so good returning the favor - it's probably more "profitable" and satisfying than any commission you could have charged. I know - now that I am an "old codger" that the most valuable and pleasant memories I have are those where I have helped other people. They are worth far more than any monetary pay I have received.
love that top !!!
Mark J Valsi
>Wow, Dave,
Nice table, but . . . THAT TOP IS AMAZINGLY BEAUTIFUL !!!!
Re: Wonderful story
David Yoho
>It's hard to say how dark that cherry will get, given its exposure to daily sunlight where it will reside. However, I expect the walnut should turn lighter and the contrast will still exist (I hope).
Re: Nice job, David!
David Yoho
>Thank you, Ellis. I might just contact Shop Shots and see how they feel!
David
Re:Nice story and nice grain on the top.
Dale Lenz
Dale Lenz
>Loved the table, David. Think I like the journey of the story best. Seems... I've tried Watco and takes for ever to dry, feel greasy. Any words of wisdom?
Thanks again for the post.
David Yoho
>Dale, no words of wisdom but a few thoughts -
Since my shop is climate controlled, I think I get better results this time of year due to the lower humidity inside.
When I was working on the table base, I noticed it felt tacky but the top didn't after the same amount of drying time. I think the difference is in the grain characteristic of the two woods. That said, what I've found that helps solve this tacky feel is to burnish it with a soft, dry, clean cloth and wait a day before more oil.
I apply the first coat with a foam brush, flooding the surfaces. Then I rub and rub and rub with 320-grit wet/dry paper, creating a slurry with the dust and oil. I wipe off all excess and check back every 15 - 20 minutes to wipe away any bleed-back. The next day I apply a little less with a paper towel and rub a bunch more with 600-grit wet/dry paper. Wipe away any excess and check for bleed-back again. I usually give this two days before applying any more. Before the third coat I like to give the surfaces a vigorous "buffing" with a soft cloth. I apply the third coat very thin with a dampened paper towel, wait about 15 minutes, and wipe away any excess. I might do this up to five more times, depending on how things look. After a couple more days, I wax and buff and it's done. The outside always feels dry and smooth to me. That's my story and I'm sticking to it!!
David
Fred Davis
>Thanks for sharing, hard to believe that's your first tapered leg job, very nice.
FredD
A beautiful piece made all the more...
Stuart Hough
>special by the history of the participants! Way to go David!
Dale Lenz
Dale Lenz
>David,
Thanks for the reply, I'm sure an open porous wood of say oak will hold more oil than cherry. So...What I'm reading is: it take you 7 days to finish a piece, is that correct? Have a "special" cherry flag case for a nephew, car wreck, that might be perfect to try the Watco on. Will finish the inside of case with shellac in case any oil is still not dry. So... The Watco I have says on the can: Watco Danish oil, is that the correct formula you use?
Ron Jones
>That's a wonderful story and a wonderful table. I'm sure it will be in your friend's family for years.
>Good Afternoon David,
That is a very special table, and your friend would have to be crazy not to appteciate the obvious extra effort expended. Love the top and inlays, choice of woods.
George.
David Yoho
>Yes, plain old Watco Danish Oil. Definitely use the shellac inside - not the oil. Also, should you set the cherry outside in the sun after applying any coats of the oil, keep an eye out for bleed-back.
David
Thank You and The Rest of the Story
David Yoho
>Thanks to all for the nice comments. I like to think this was another chance to give back. However, although there was no monetary gain for me, there was a chance to test and learn a new skill - tapering legs.
The rest of the story -
To create the profile on the front and rear aprons, I had to do some head scratching at first. I'd marked the maximum height of any type of arc I'd use in the centers of all apron pieces. I quickly realized a simple arch wouldn't work for both. I decided on a simple arch on the end aprons but what to do with the long aprons.
After diddling with a few profiles, none of which were pleasing, I stumbled onto the final profile when I grabbed a template I had hanging on the wall. It was long enough to yield half the final profile. I picked the best starting and stopping points from the template's profile and marked them to be able to repeat on the other half of the aprons. After transferring it to the other half, I ended up with what you see. The funny thing is the template I used is for laying out the contoured seat supports for a porch swing I build!
David
Alan Young
If you want-I'll put in a good word for you
Alan Young
>with the SS editor.
Great table David. Sturdy but graceful proportions. I like the edge banding on the aprons...
Alan
