My lacquer is embarrassed
Dale Lenz
>Spraying lacquer today, 100% RH outside, got the whitish-blushing effect for the first time. Added about 20% S-W Butyl Cellosolve, lacquer retarder to the mixed, seemed to solve the problem. My questions: What can I expect from adding the lacquer retarder; slower drying time between sanding. Usually, let item cure for 3 days prior to polishing out lacquer for high sheen. Will I need to allow more time, 4 days? Any noticeable difference in sheen, more difficult to get sheen because of less brittle material, etc.
TIA,
Dale
