Wood decks
Wood decks
Wood decks
Casey Schmidt
>What is the material used on teak boat decks to create the black stripe between each board & how is it applied? Because teak has become so expensive, can ipe be used and can it be glued to a base rather than screwed down?
Re: Wood decks
Re: Wood decks
Pat Evans
>The black stripe is silicone caulk. A Google search on teak decking will get you lots of info. Don't know about ipe.
