>Has anybody tried to bend lacewood? Hi- I'm back again with the barrette thing. Mesquite, hard Maple, and Wenge works well with steam but I'm having trouble getting lacewood to bend. I looked it up online and it says "excellect bending quilities." What gives?
>Lacewood is a common name that can refer to at least three species of lumber that I know of, including quartered European Plane, Australian Silky Oak, and a South American look-alike which I can't name offhand. The first two reportedly have excellent bending properties; I don't know about the Brazilian version.
Another possible factor here is that green wood is best for steam bending. Once the wood has been kiln dried, it is often fairly resistant to bending. Even prolonged soaking or steaming doesn't always work so well.
Depending on the radius of the bend, the thickness of your blanks and the moisture content of the wood, you just might not be able to bend these barets as easily as you would like. Two alternatives would be to either bandsaw the shapes, which would probably be strong enough but might mess up the appearance, or laminations, where you rip veneers and glue them over a form. This might be your best choice.
>we have steam bent many a Morris chair arms from quartersawn white oak 1 1/8th thick 5" wide and 42" long. I tried cherry for the first time this past week. I told my student we would try once and if the cherry failed we would bandsaw the arms out instead. I am most happy to report that the stars and moons must have been in line because we had great results. Must have beeb just luck maybe!
