>We have a nice floor lamp that uses a 50-199-150 watt 3 way bulb, but is actually a variable intensity dimmable lamp. The lamp switches on with a rotary switch mounted on the top post of the lamp...clicks on by twisting clockwise, getting brighter as the knob is twisted farther clockwise.
The original bulb (a standard 3-way) blew a couple of weeks ago when the lamp was moved while still on. I did not have a replacement, so I put in a standard 100 watt bulb. The switch did not work with this bulb; it was "on" all the time, and would not turn off. I just twisted the bulb in and out to use the lamp temporarily.
Today I bought a new 3 way bulb and screwed it in. Even though the switch was in the "off" position, the lamp still came on. The switch controlled nothing...not on, not off, not dimming. Obviously something is wrong, but I don't know what.
I can add that when the bulb is screwed in, it feels like it is getting snug, then the bulb "slips" a bit and it can be snugged again.
I can handle most home wiring jobs, but this type of switch is new to me. Can anybody help before I start blindly tearing a nice lamp apart?
Re: OT-Variable dim lamp uses 3way bulb; quit working
Dan Donaldson
>If it uses a three way bulb, then the switch is set up so that the lowest wattage comes on at low, the middle one in the middle and both at high. It is possible that you have damaged the socket it goes in, but the fact that it won't turn off leads me either to the switch or a short in the wiring feeding the socket. Take a look in the socket (unplug it first ;-) and make sure you can see all of the contacts and that none are bent or broken. If that is OK, then you will need to open the lamp and take a look at the wiring to make sure it is all tight. If so, then I would guess the switch. You can get replacements for them at the borg or a lighting store.
>To clarify, this lamp is not the standard low-medium-high 3 way lamp. It requires a standard 3 way bulb, but the bulb actually can be dimmed anywhere from night lite to bright lite using the rotary switch on the lamp, not just in one of three positions. Think standard rotary dimmer switch, but using a 3 way bulb instead of a standard bulb.
>In that case, I would suspect that the dimmer is faulty. I have had the case where a lamp blew and took out the dimmer. There is sometimes a fairly large surge when an incandescent lamp blows out and that could damage it. They are not potentiometers, but rather a triac (electronic) system, and can be damaged by surges. In this case, unless it has a generic type of dimmer, you may have to go back to the manufacturer of the lamp to get a replacement.
>We have the same type of lamp except it has a standard 100 watt bulb. The brightness goes from off to full 100 watts. I'm not sure what a 3 way bulb does other than vary the brightness of each 3 way setting. It seems like a single wattage lamp will have any brightness between 0 and the max wattage of the installed bulb. The switch does have an off position but sometimes the lamp appears to be off because the bulb is dark and cool but the switch has been turned down, not all the way off.
Howard Norman
>I have not seen a lamp that used a dimmer circuit and a three way bulb. Don't know why you would want to do it that way since three way bulbs are always more expensive than a single wattage bulb. It sounds to me like you may have fried the triac when the bulb shorted out. It that is the case the control circuit will have to be replaced. I would probable replace the socket with a regular bulb socket with a standard dimmer circuit. Probable cheaper and certainly cheaper with light bulbs.
