Renting Floor sander questions (OT)
>I have a couple of hardwood floors that need sanding. One near the Apex/Cary area in NC and the other at my house in Chester, VA.
Does anyone know how to rent or where to rent one of the floor sanders that has the four random orbital sander built into it. I see them on the "fix it" shows on TV but have not been able to find one to rent. (OK, I have not tried really hard, but I thought I would ask here first.)
A second question. Anyone have experience with these machines? one floor I am patching and will have a random mix of old and one flooring and one that has had black glue scraped off it. The other has the Vee Grooves in it and I will have to sand a lot off it. Any advice?
Re: Renting Floor sander questions (OT)
Don at Central Illinois
>Barry, here in the heartland, I've not been able to rent one of those sanders either. I've been stuck with the old belt sanders but have had really good luck. Luckily, I haven't had to do this for a few years. Hope my luck holds out and good luck. If you find one to rent, give us a product report.
George Koch
>Barry, try the local home depot rental. That's where I got one to do a large deck. It worked great for that. George
Nat Robison
>I know that Lowe's (here in the Detroit area) rents the Varathane Sander with a 3-ROS System. I'm not sure what HD rents here. The Varathane sander is easy to use and produces very little dust but is very heavy. You might need help getting it up steps or into your vehicle. I think that the ROS-based machines do not work as aggressively as a belt-based sander. They're better for refinishing a floor that's in decent shape, not one that needs major leveling.
As has been discussed here before, you're asking a lot of a machine to eliminate V-grooves from a floor (1/8" or so). You might find it's a ton more work than you bargained for and might be difficult to have the whole floor in the same plane when you're done. Even with the 36 grit pads on the ROS-based sander, it wouldn't take out all of the dings and scratches.
Disclaimer: I've done floors once with an ROS-based system....no experience with a belt-based sander.
John E in SC
>I put new hardwood in my bedroom a few years ago, and local rental shop (not a very big one at that) had a random-orbit floor sander with 4 disks that I used. They even had a similar one at the local Lowes with 3 disks for rent. However, with the situation you described, I suspect you will need a floor belt sander. My new maple floor was pretty level, but even with very coarse sandpaper, the ROS was pretty slow going. It took me about half a day to sand out a 320 sq ft room. (Can't remember how many different grits I used, but I'm sure it wasn't more than 3) I've never used a flooring belt sander because I've seen too many floors messed up by them, so if you decide to use one, be careful.
Re: Renting Floor sander (OT) - long response
Kevin Mac Luskie
>Barry,
I believe the partiular unit you are referring to is the U-Sand (http://www.u-sand.com/). I recently did some refinishing of Southern Yellow pine flooring(64 sqft), and new install of QSWO flooring(900 sqft) at my house.
I found the U-Sand at United Rental, and Grand Rental Station (Hampton Roads Virginia).
The U-Sand worked very well on my Southern Yellow pine refinish. I started with the 40 grit, but wished I had started with the 36. After the 40, I went to 80 grit, and stopped there. It was as smooth as 120 grit off a floor drum sander. (I returned the 120 grit ROS pads I had bought for the U-Sand.)
It is slower than a drum sander, but safer. It took about 2 hours start to finish on a 64 sqft 1/2 bathroom. It would have gone faster if I had started with the 36 grit.
I also tried to use the U-Sand on the newly installed QSWO. And even if I had the 36 grit, I don't beleive it would have been addressive enought to flatten out the high spots. It tended to just round over the edges of the high boards. I ended up renting a drum sander for 1/2 a day to do the course sanding. I had gotten the U-Sand initially cause I was scared of messing up my new floors. This turned out to be an unjustified fear. (at least with the oak flooring) I started out moving pretty quick with a 40 grit sheet on the drum sander, and had to do that section 2 more times before I finally slowed down enough to be able to do it right. You only move the sander over 2-4 inches with each pass, so there is a lot of overlap, and time to blend together. Wasn't scary at all after a bit.
Since I already had the U-sand till the end of the day, I used it for the finish sanding. It gets close enough to the walls, that I didn't have to use the small hand held edge sander. I just went around with the 40 grit around the edges, then switched to the 80 grit for the whole thing, and it was nice and smooth.
Advice: 1.)If you have a lot of height variation in your floors, you're best off going with the drum sander first to get it all flat. Then if you are having trouble getting a good finish with the drum sander, switch to the U-Sand to finish it off.
2.) If the room is too short the direction the wood floor is oriented, less than about 8 feet, the drum sander might be more pain than its worth, just use the U-Sand.
Hope that helps.
-Kevin
Glenn Madsen in the SF Bay Area
>Are you going to try to sand off the black gunk? I wouldn't. That's just me, though. But heating up that stuff with friction is going to make an awful mess.
It might be time for the pry bars...
disclaimer: I've done 1 sanding job with the belt sander 25 years ago, and it wasn't pretty. Done another 2 with the ROS types, on better floors, which turned out all right. Have been much happier with the prefinished engineered flooring work, modest, we've done on two smallish rooms.
Good luck, friend!
>I have been experimenting on the black gunk. (Excellent description) Tried just scraping it. About pulled my arms out of the sockets. Then I tried my power plane. Worked great for about two minutes, then the gunk caught up with it. It will take an hour to clean the plane, maybe more.
Then I tried the Orange paint stripper. Not much help. Then the Jasco glue remover, Nasty stuff, but much better. It will be a sit on your butt, paint on the stripper and scrape kind of day. Not looking forward to it.
But you are right, it would take more square feet of sandpaper than there are square feet of flooring.
>My thought would be to look at what it would take to replace the floor, economically with engineered stuff, vs. paying for the stripper, sanding materials, finishing materials, etc. Even if the time were a wash, (it won't be), you'd have a better look at it for the decision.
The Orange Borg on occasion has decent engineered veneer prefinished at about $3/ft. You could be done by Friday, probably. And the room wouldn't stink like Jasco.
Kevin Mac Luskie
>In one hallway of our house, we had tiles glued down with the black gunk. My wife ended up sitting on the floor with De-Solv-it (http://www.orange-sol.com/household/index.html) and a couple of green sos pads. It took about $10 worth of cleaner to do the hallway. ~30sqft. not sure I'd want to do it on a larger area. But it worked well, and on the plus side, the stuff smells nice.
>Would a heat gun help? I know I've used a heat gun to soften black mastic and take the majority off with a puty knife. Good luck.
