Veritas - Innovation in Tools
cup placement for concealed hinges
Bill H - Evansville, IN
>I am using 1 1/4" full overlay concealed hinges (face frame) for some cabinets that I'm making. If I move the cup close enough to the edge of the door to get a the full 1 1/4" overlay that only leaves me 1/8" of material between the cup hole and edge of the door. This seems like too little material left on the edge of the door. Am I doing something wrong? Is 1 1/4" a nominal measurement? Will I only get ~1" of overlay out of these hinges?
Thanks in advance,
Bill
Re: cup placement for concealed hinges
Sounds about normal
Lee Schierer - McKean, PA
>I have limited experience with cup type hinges, but that amount of clearance to the edge of the wood is typical for what I have seen. Unless your door is particularly heavy it should work just fine. If it is a really heavy door consider using 3 or 4 hinges.
Lee
It's normal
>I've used many Euro-style hinge brands over the years and they all end up with from 4mm to about 6mm between the cup hole and the edge of the door when properly installed. Keep in mind that the screws or plugs are what hold the cup to the door, so the cup itself exerts very little force on the edge of the door. It is more for restricting any movement in the x-y plane. The actual relationship of the door to the cabinet is determined by the adjustable hinge mount that gets attached to the cabinet wall or face frame.
Ellis Walentine, Host
John Foster
>I agree. on my maple cabinets I have had to cover my errors a few times, and place the cups with just a paper thickness of wood between the cup and the door edge, and no problems.
