OT - Insulation and Knob & Tube
Joe in a Cleveland suburb
>Hi folks.
I just spent a while searching the archives for an answer to this. The only thing I could find was this thread by Barry.
I am wondering, if in an early 1900's home with knob and tube wiring, what issues are there with having foam insulation blown in?
I am guessing it's not a good idea to have foam blown in around the old wiring. Secondly I am guessing that with these old houses buttoning them up tight with insulation and new windows can cause other problems with moisture build up, radon gas issues, mold, and so on.
Some might say replace the old wiring with new (this in in regards to exterior walls btw). This I would guess, done properly-to code, would get very expensive. You'd probably have to upgrade the service panel and all kinds of stuff - just guessing, I'm not an electrical do-it-yourself kinda a guy. Maybe so much so that insulating isn't cost effective?
Somebody I know is considering this. I thought I'd check in with you pro's on the pro's and con's of doing this.
Thanks for any insight.
