Festool Kapex *LINK*
>In case anyone was curious about the Festool Miter saw I was sent this link to Festool's promo video. You can check it out if you like. I'm posting the link only as information not to promote it. I have not seen the saw in person. It lists for $1,300 so you can decide for yourself if it seems worth that. It's an interesting debate.
Tom
Kapex
Re: Festool Kapex *LINK*
Re: Festool Kapex
Brian Gray in Sandusky, OH
>There's a discussion similar to this below...
I think that we need to try and not lose sight as to who Festool's market is....
Trim carpenters. Not cabinetmakers.
As cabinetmakers, we can cut perfect miters on a miter sled at the TS. And if we are a little off, we can shoot them by hand.
But if this tool is dead accurate every time and absolutely repeatible, and equally importantly - portable....
...would a professional trim carpenter buy it? Absolutely.
Don't totally agree
>I disagree to a point. Who would use it and how it would be used is more a matter of preferrence. I'm a furniture maker and I would welcome a good accurate slider saw. I do agree that accurate miters can be done with other methods, such as those you noted. But for me, time is money. Setting up my TS and a sled to cut miters takes extra time. Whereas if I could dial in an accurate miter on a slider it would only take me seconds and I could leave my TS set up for other work.
Tom
Re: Don't totally agree
Glenn Madsen in the SF Bay Area
>My immediate response was that this jewel was 4 times the cost of the perfectly usable saw in my current shop setup...
Now, I appreciate fine European engineering and craftsmanship at least as much as the next fellow, but I don't think I'm in their target market.
...their target market
Roger Lance in GR, Michigan
>want to have some fun...get a tread going about just what is their target market and the psychological profile (not just financial profile) of the people who are targeted to buy expensive/prestigous items and also illustrate some of the routines that are used to separate these targeted individuals from their money...I'm betting that such a discussion goes nowhere because there are some painful truths to be faced.
Re: Festool Kapex
Sawdust Everywhere!
>Ok,
I went to view the link....
Says change blades with one hand using some built in contrapption on the saw...
But it clearly shows the demo guy using 2 hands! Especially when swapping the blades!
Good Point, Thomas...
Brian in Sandusky, OH
>I'll revise my statement.
Their target audience are professional trim carpenters and some professional cabinetmakers.
Here's what it would take for me personally to buy that saw...
If I were doing lots of crown molding.
I HATE cutting crown on the table saw, and I just don't do it enough to practice and really get it perfect every time on a standard miter saw.
When I do crown, I buy and prep triple the stock that I might need for it...I need a lot of fudge factor for crown.
That saw might be the answer to that trick, and if so, it's probably worth the money to trim carpenters and cabinetmakers that do lots of crown.
Re: Good Point, Thomas...
>I think that the investment for trim carpenters is to do it well for long enough that the available tools do the job for you.
Not for me. I'm a homeowner/hobbyist type. I may get good, but I'm not likely to do it at the expense of the $1300 sliding miter saw. And it won't happen this year, either. I'm still learning on a kitchen build out. And there is at least one more of those lined up.
