Shellac rub out method sought HELP!
Alan Tolchinsky
>Hi All, I have some small boxes that I finished with shellac. I wiped on a lot of 2lb. coats and got a pretty good surface. But the rubbing out seems so labor intensive. I'm starting with 400g sterated paper then 0000 steel wool. After this I wax and shine. I don't like waxing with steel wool as I can't judge the progress. The slow part is the 400g paper; it seems to take forever to get rid of all the shiny spots. Is there a quicker method to a satin shellac finish? I'm starting with a good shellac surface to begin with. What's your method?
Re: Shellac rub out method sought HELP!
Jeepers, Alan, this is a tough one to answer,
Eddie Pacheco; San Jose, Ca.
>Many a magazine article and book chapter has been written pertaining to rubbing out a shellac finish. Check any of the Michael Dredsner finishing books, along with one by Teri Masaschi "Foolproof Wood Finishing: For Those Who Love To Build And Hate To Finish" for step by step instructions on rubbing out shellac.
I also start off with 400 grit wet/dry paper wrapped around a cork sanding block and used with a 50/50 mix of mineral oil and thinner. I then progress through to 800 or finer depending on the box or who it's going too. Moms always, and sisters that were good during the year get the finer finish. I don't use steel wool at all.
I'm guessing you're not using a sanding block based on your statement "that it's difficult to get the shiny spots out". These glossy spots are low spots on your finish. Using a sanding block will better help get these level quickly.
In a nut shell;
1. get a cork sanding block
2. use the 50/50 sanding "lube"
3. use 400 thru to 600 or 800 grit wet/dry paper. (up to you)
4. get rid of the steel wool,
5. wax and buff as final steps.
If you want to get close to a French polish it will take several more steps.This final stage of finishing is almost as boring and labor intensive as sanding.
I'm sure others will pitch in with variants of the above. Be sure to check out the finishing books.
Good luck.
Steve Schoene
>400 grit is quite aggressive for final rub out, so from that point of view you are moving about as fast as you can leveling the surface.
You can achieve a lower quality satin surface by just using the 400 grit to remove major blemishes if any and then shifting to the steel wool to achieve the satin finish. How you lubricate the steel wool will also impact how agressively it cuts. Lubricating with wax is less agressive than lubricating with mineral spirits for example.
Frankly, I'd just suggest patience and do the full levelling process with the 400 grit before shifting to finer grits, or steel wool, for the final finish. It really will look nicer.
Howard Acheson
>There are a couple of points that I want to make.
First, rubbing out is greatly facilitated by how smoothly the finish was applied in the first place. Brushing on multiple coats of shellac can be problematic as it's fast drying gives little or no time for the finish to self level. My steps are to apply the first coat with a brush flowing it on. Then I sand with 400 paper after letting it dry overnight. At that point I switch to padding on subsequent applications. A properly padded on finish is much flatter than a multiple application brushed on finish. The smoother initial finish means that subsequent rubbing out is much easier and faster.
Second, shellac is not a finish that should be "built" to a thick film. It's a finish that is best applied very thin. It will stay much flatter when thinly applied and you will not run into cracking and crazing after a year or so. Shellac is a very hard and, therefore, brittle finish. It does not take well to the seasonal wood movement if the film thickness is too thick.
So, I would recommend you pad on 3-4 applications after the initial brush application. You will have a smoother finish--and a padded on finish should be good enough that you don't need to go through a rubbing out process. Give it a try on some scrap before you do the next project.
Alan Tolchinsky
>Thanks all for the help. It makes a lot of sense to me. I'm wiping all the coats on now but will try to brush on the first coat then wiping on the rest. It looks like I'm on the right track so I'll just fine tune it with all your suggestions. Thanks a million for all the detailed help!
