Headphone radios
Randy Stukenberg
>Does anyone have one of those headphone radios (worktunes, Peltor, Quietunes, etc.)? Do any of them have a decent AM radio? I would like to get one, but not sure which is best.
Any suggestions?
Thanks!
Headphone radios
Randy Stukenberg
Any suggestions?
Thanks!
Re: Headphone radios
Neal in San Jose
>Good news, Bad news. I think mine are Peltors, and they do work, and they are good at noise reduction. The bad news is that they are really touchy to tune, and all you have to do is bump them, and they jump off station. Mostly I don't use mine; just too much trouble.
steve mackay
>I've tried a couple over the years. In my uninformed opinion they're all over-rated. I found I liked ear buds tucked under my regular muffs better. I tucked a walkman in my back pocket. Never had one but I'll bet these new fangled " I-thingies" would be even better.
Rob Stokes in North Vancouver
>To play devil's advocate here... As a woodworker you'll wear ear protection when you're using power tool. Table saw, jointer, planer, bandsaw, circ. saw, sander etc.
I'm thinking that if you're conscious enough about your hearing to be safe and wear good ear protection, you'd be conscious enough about your finger length and do everything you could to eliminate any and all distraction while you're using those power tools.
Why on earth would you choose ear protection with a built in radio for these tasks?
Rob
Hear Here! :
Seems to me that..............
Howard Acheson
>....the question to be asking is which offer the best noise reduction, not the best radio reception. Both Wood Magazine and ShopNotes or Woodsmith did a review in the past 4 or 5 months.
I wouldn't....
Randy Stukenberg
>use it for sawing operations, but... sanding and lawn mowing (2 1/2 hrs) can be pretty boring...
mdclor
>I like the Worktunes that have 26 db reduction. I like them for the noise reduction for my dust collector that I leave on rather than turning it on and off.
FWIW,
Merle
Re: I wouldn't....
Kneale Brownson Dreaming of the Snow in N. MI
>I have the Peltor Worktunes radio headset I wear while operating tractors, lawnmowers and grinders.
For woodworking tools, I usually use non-radio earmuffs.
The AM reception locally is not as clear as the FM, at least for me. I almost exclusively stay on FM, which is great. Neither format works very well when the batteries start to run down, however.
Ken Platt (Granby, CT)
>I have a couple different ones. One is AO Safety Worktunes, which IIRC is the same as the Peltor. They work as advertised, but aren't especially good at radio reception of not-terribly-strong signals, so if your favorite station(s) are a bit weak (as mine are - the two closest NPR stations are both a bit hard to pull in up here in the hills) it's a problem. Noise reduction seems very good.
I got another pair from LV because they had an input jack for an mp3 player. I'm not very fond of them though because they are shaped a bit oddly, intended for a very wide head. Maybe my head is abnormally narrow, but they feel awkward because they stick out sideways from my head. Also, the mechanism for adjusting the ear cups up and down is just plastic and the ear cups tend to slip down, so I have to readjust it a lot.
I've mostly gone to using my mp3 with earbuds under my regular, nonradio earmuffs. And, as mentioned above, never while sawing.
Ken
