Stud finder?
Stud finder?
Stud finder?
Pat Evans
>I have a Zircon Pro SL studfinder that is essentially useless. I am trying to get Mom and Dad moved into a retirement home and there are several areas that need shelving. If anyone can recommend a decent studfinder, I would really appreciate it.
Re: Stud finder?
Re: Stud finder?
Lee Schierer - McKean, PA
>I have a zircon stud finder and have not had any problems locating studs. My walls are plaster over blue board and nearly 3/4 thick. I have noted that it is sensitive to how it is held and it must be kept tight to the wall at all times. If you get you hands too close to the sensing head it will give false readings.
You can also find studs with the Little WIzard metal detectors. It will either find metal studs or will find the nails/screws used to attach the drywall or lath.
Lee
Re: Stud finder?
Thanks Lee
Pat Evans
>I have used the little plastic studfinder with a pivoting magnet, but it is agonizingly slow. I wasn't smart enough to think of using my Lumber Wizard. I will be using it this afternoon.
Re: Stud finder?
Re: Stud finder?
steve mackay
>I've got the cheaper red Craftsman. Think I gave a whole ten bucks for it. Theres just a couple LEDs down the middle for bells & whistles. Thats it. It seems to work a bit better than "hit & miss" on dry-wall although I still think all "stud finders" are on the same cosmic rung as dowsing rods (just my opinion). My only other beef is that I THINK they might key on heavy repair patches in the wall also. Like I said, I consider them a bit on the "mystical" side but its right more often than wrong.
Re: Stud finder?
Re: Sweetie is amazing at...
Al Stokka - Cambridge, Iowa
>...finding them. She found me within seconds! Sorry, I'm not loaning her out. ;^)
Al
Re: Stud finder?
I knew somebody had to say it :-)
Re: Stud finder?
Re: I waited for Skaggs as long as I could. ;^)
Re: Stud finder?
Re: Stud finder?
Justin
>Electrical outlets are most often found attached to studs, & most studs are 16" apart. A knock on the left side of many boxes generally will sound a bit more solid than on the right, indicating the box is mounted to a stud. Helps to check multiple boxes, measure to see if they are 16" apart. Once you find a box mounted to a stud, you can measure over & see if the wall sounds more solid every 16". Just knocking on the wall to see if you can hear where the studs are behind the drywall or especially the plaster can lead to lots of little holes where the screws didn't hit a stud.
You can also look at the wall at an angle, standing close to the wall looking in the direction of a light source to see if you can see seams in the drywall or nails. Sometimes on less than well finished rock I can spot the fasteners or seams.
I personally think stud finders are a bit of a waste of time, money & storage space. Never found one that was reliable.
If you are installing shelves you could also use toggle bolts, as they are pretty strong.
Peace
Justin
