On making a 6 panel door
Bill Tindall, E.TN
>Maybe it is a retirement thing but I find I am reluctant to buy anything I can make now days. I like a panel door with a large rise on the panel part and it is not to be found in doors at Lowe's. I have made all sorts of raised panels for furniture and cabinets, so why not a door?
Now my friend has a door set for his shaper that makes short work of making a door but I have been waiting 10 years for him to get the bushings to be able to make a thinner door like for closets rather than the 1 3/4 doors he makes. So, I had at making the doors with tools at hand. About the only secret beyond what is already needed to make a frame and panel for a cabinet door is to find straight vertical pieces.
Wife was pleased with the result and that is what counts.
Re: On making a 6 panel door
Bill Roland (Mt Juliet, TN)
>Great looking doors. Oh what satisfaction we get when we make it ourselves.
So Bill.....
>....is it a six panel door or 2 three panel doors? ;-)
Regardless, very nice work.
Tom...an admitted buyer and not maker of doors.
brain spasm
Bill Tindall, E.TN
>2- 3 panel doors. The opening was an inconvenient 3'. One 3'- 6 panel would have been too big in the hallway, but I was going for the 6 panel look. I didn't want the aggravation of a bifold as this closet is where my work clothes are kept and I am in and out of it all day. A hinged door is more successful for the need.
Re: Still a great solution
Kneale Brownson Dreaming of the Snow in N. MI
>The more do-it-yerself stuff I do, the more I want to be self-reliant. Aside from spending a dollar to save a quarter, it's mainly the internal rewards I'm after. And, in your door case, there's almost no other way you could have made your desired design fit your required specifications.
Another great job you've done, Bill.
Hamish
>Hi Bill,
Your doors look reallu great. You mentioned that you had to use your tools at hand. Would you mind telling us all what they were, as I have a wardrobe door project looming up.
Thanks a lot, Hamish.
directions
Bill Tindall, E.TN
>The frame is mortise and tenon joinery. There are a multitude of ways to make M&T joints. I use an attachment for my drill press or sometimes I chop them by hand.I saw the tenons on the table saw and fit with a plane.
The panel sits in a dado which can be cut on a table saw or with a router. The panel bevel was sawed with the table saw and cleaned up with a plane. With patience it can be planed instead.
The molding is the tricky part. It is a "false cope", see picture. I am not sure if I can successfully explain how to do it. If I had a picture of the vertical part unassembled it would be obvious. A miter is cut on the end of the molded edge on the horizontal piece. The molding is cut away from the vertical piece where the horizontal piece joins it, and a miter made on the end of the remaining molding to fit next to the miter on the horizontal piece. It winds up looking like a coped joint, but it is easier to make if one does not have the mean or patience to cope the molding. Keep in mind that the horizontal piece needs to be made longer than you might think to include the extra length where the molding is cut away from the vertical piece. I have made this mistake at least once. Clear as mud? Maybe someone else can help explain............
