THE WOODRAT IS BACK!
Color lacquer
Color lacquer
Color lacquer
John Fin
>I am looking for a colored lacquer product that I can spray on a vintage mahogany victrola. Any ideas?
Re: Color lacquer
Re: Color lacquer
Ken Oakley-Sunny St. Cloud, Fla
>Try any automotive paint supply shop or store in your area. Most can mix a color to match your need.
Re: Color lacquer
Re: Color lacquer
>Assuming you want a transparent stain, you can mix it yourself, using NC lacquer as the base, tinted with alcohol soluble aniline dye stain.
Clint
Re: Color lacquer
Re: Color lacquer
John fin
>I need the finish to be opaque or more solid. Here is what I want it to look like when I am done. Looks dark brown but its actually a dark red mahogany.
Re: Color lacquer
Re: Color lacquer
del schisler
>I use M.L.Cambell lacqure all the time The one i use is Magnalac It is the best i have used Fast drying time It is a cabnet grade Here is the page for dye lacqure which i havent used yet
http://www.mlcampbell.com/pages/family.asp?fam=STN
Re: Color lacquer
Re: Color lacquer
del schisler
>More on M.L.Cambell Lots of info on this page It open's up in a pdf and you can get all the info you need fJust scroll down and select what you are looking for del
http://www.mlcampbell.com/resourcecenter/pi_resource.asp
Re: Color lacquer
Check out http://www.woodcraft.com/family.aspx?Fam
