Not Really OT, but a little different...
Glenn Madsen in the SF Bay Area
>My son has been using my shop resources to build a laminated surfboard. This one is his third.
So this afternoon, he calls me and asks about spar varnish. Now I know something about spar varnish, and have used a few quarts on kitchens and baths and such. But he's asking about using it over a resin/poly fiberglass type of finish.
Question #1: Would this work in any way that any of you know of?
Question #2: Would there be any value to using this over the fiberglass clear surface? Would he get a better finish for actual use?
Question #3: Is there a better spar to use than the McCloskey's that's sitting on the workbench now? If so, what would that be?
The board is really pretty now, laminated up of redwood and powlonia, built over a thin Finply structure like an aeroplane wing from WW2 era England. The Finply was cut on my neighbor's Shopbot, and they got backbones for at least three longboards out of one sheet of the plywood.
So what about the spar over fiberglass? Any thoughts? It's outside of my league...
Re: Not Really OT, but a little different...
MIke Johnson
>When I built a cedar strip canoe with a fiberglass and epoxy coating, the book of instructions was adamant that a UV resistant varnish be used for the finish coats. It will work fine and protect the board from sun damage. I used a product called Z-Spar Captain's varnish sold by Raka Epoxy.
Jesper, Denmark
Jesper, Denmark
>The spar varnish will be good protection from UV, but maybe too slippery for a surf board?
No problem adhering to the glass.
>Thanks, guys!
I don't think slippery will be a problem. It gets a wax coating on the foot board area that helps keep the slipping down.
Appreciate the tip on the spar varnish brand, too!
Hamish
>Glenn, back in my teenage days, I used to do a lot of dinghy racing, and I used to add a sprinkling of very fine sand on top of my wet yacht varnish where I wanted a non slip surface, and on the hull, I used to sand down the final coat of cured paint or varnish with 600 wet and dry sand paper, used wet, to reduce the surface tension and make the boat go faster through the water. It really worked.
Have fun, Hamish.
>So last night, he comes in and indicates that he's going to put one more thin coat of epoxy resin on it, and call it good. This thing is looking really nice, and I think he has put together a piece of art. Whether he can ride a wave with it remains to be seen.
Thanks for the ideas, guys. It's nice to have somewhere to ask strange questions and get reasoned answers.
