Jointer adjustment help
Craig McCormick
>I am trying to adjust a jointer and the directions that came with it are horrible.
I took a piece of 1"X3"X36" pine and face jointed it. I passed it over the jointer 4 times and the leading end that was fed into the jointer is thinner than the trailing end by a significant amount. Is this a table to table adjustment problem or do I need to adjust my out feed table in some direction? Or something else???
Thanks,
Craig
Re: Jointer adjustment help
Which jointer?
Chuck W
>What kind of jointer is it? Check the outfield table height relative to the height of the knives. Put a straight edge on the table and rotate the cutter head. The knives should just rub the straight edge slightly.
Tony - Memphis
>Well, you could get that if the piece was originally convex. If the piece is convex and you push on the leading edge, it will get thinner the more you run it over the jointer. Also, a lot of folks make the outfeed a hair higher ( a few thousandths) than the cutter. That's how I set mine too. Good luck. For such a simple machine/concept, they can be difficult to get setup correctly.
Tony
It's might be something else
>If I understand your situation and question, are you face jointing the 1x3x36 piece and expecting it to remain the same thickness from end to end? Is the piece becoming a long wedge (ie. it starts at 1"x3" at one end and becomes 7/8" x 3" at the other end?
If this is the case, there may not be any problem with the jointer. About all a jointer will do is make on face or side perfectly flat. You need a planer to make the other side parallel to the newly flattened side.
Happy Woodworking!
Rick Christopherson
>Probably the most likely cause for this when face jointing is due to a sagging outfeed bed, and you are transferring your guidance of the board from the initial infeed side to the outfeed side. This causes the board to tilt upward at the tail end when you transfer to the outfeed side. It doesn't take very much sag, especially with multiple passes, to cause a taper.
I don't face joint with my jointer, so I don't know how applicable this would be for face jointing, but when edge jointing (i.e. when the board does not flex with down-pressure) I do not transfer my guidance from the infeed to the outfeed side of the jointer.
In theory, if your jointer was perfectly flat, it wouldn't matter how you fed the workpiece through, but because a sagging outfeed bed is extremely common, not transferring guidance makes up for some minor misadjustment. The reason is that you begin the operation with guidance from the infeed, but then halfway through the operation, you change guidance to another surface. The jointer is the only tool where people routinely change their reference surface in the middle of an operation.
Admittedly, I do believe this approach is less appropriate when face jointing.
Craig McCormick
>Thanks all for the ideas. The jointer is on my Robland X-31 combo machine.
I re-adjusted the out feed table to the blade height and ran another 1"X3" through it making sure I only applied down force on the in-feed side and got much better results.
Thanks again,
Craig
You probably have less chance of a flat surface
on Henthorn
>if you use the in-feed table as the only reference plane. Standard procedure is to begin the cut using the in-feed table as a reference and as soon as enough material has passed over the cutters to allow, shift the reference to the out-feed table and continue from there. If you are getting a wedge shape then you need to check your table set up as Chris said. You don't need to face plane more than the small amount you need to get one surface flat. If you are taking too heavy a cut and do it several times you could get the results you are seeing. You just need to get one surface flat enough to be able to use the planer for thicknessing. Good luck.
Re: You probably have less chance of a flat surfac
Steve Schoene
>I agree that the outfeed table is the one to be used as the reference surface as soon as possible. Forward push only over the infeed table, and even downward pressure on the outfeed table just past the cutter.
Checking to see that the table surfaces are parallel with each other should be done.
Rick Christopherson
>Even though that is the method commonly taught, it is predicated on the assumption that the jointer is perfectly set up, and with both beds being perfectly in-plane with each other.
In reality, most of the hobbyist grade jointers will have a slight variation in the bed planes, and adjusting this out can be very difficult. Moreover, simply changing the height of the bed(s) can knock the adjustment back out of adjustment.
Most people don't notice the problem until they make multiple passes and begin to see a taper form in the workpiece.
Fred Davis
>what other "assumption " would it be "predicated on" ?
FredD
