On making a curved top
Bill Tindall, E.TN
>For this top I am following directions as provided by Will Neptune in a demo last year at the fall SAPFM meeting. The first step is to prepare the staves for the top. 1. Determine the circumference of the circle the curved top is derived from, 120 inches in this example. (the formula circumference = 3.14 times the radius may be handy for this step) 2. Select a stave width, in this example 3". 3. Determine the angle to saw or plane the stave edges. This angle is calculated as follows: Circumference divided by stave width- 120/3 = 40 staves to complete the circle of 360 degrees. 360 degrees divided by 40 staves = 9 degrees per stave. But this angle is shared by adjacent staves so the angle on each edge is 6 /2 = 4.5 degrees. So the saw is set at 4.5 degrees to angle the stave edge. 4. Each stave is sawed 3" wide with a 4.5 degree angle on each edge.
Now the clever part. If these staves are glued up in this state there will be a lot of shaping to make the top round inside and out. 5. Leave the saw set at 4.5 degrees and turning the stave on edge saw off the top of each stave to a distance of 1/4 the width of the stave as noted in the picture by "X". This wood would otherwise have to be removed after the top is glued up. 6. Mark the radius of the top on the bottom of the stave as shown exaggerated in the picture. Using an operation like what is used to make a cove on the table saw saw, saw away the bottom of the stave just up to the curve mark. Again, this wood would otherwise have to be removed after the top is glued up.
The bottom line for the stave is as follows- the edges are angled, the top is beveled and the bottom is curved as shown in the picture.
