WAP = Wireless Access Point
>"...So I went out and got a wireless N router that...."
You should have bought a wireless N access point, which would have made your life easier.
But working with what you've got, and assuming you're wanting to keep your Barricade in place, you certainly can plug your wireless N router into it.
You can plug the wireless N's WAN (internet) port into the Barricade's LAN por, and you'll ahve a network within a network. It will work fine out of the box, however if they use the same subnet mask 192.168.?.? you'll have to change it if you want to be able to access acnything on the outside network from within your inside network. Using the network-in-a-network will work as long as you understand the how networks works to overcome the complexities you may have introduced. I run routers 4 and 5 levels deep sometimes, so 2 levels is workable.
If you're wanting to keep it all on one network, you probably can turn off DHCP on the wireless N router, and then plug the router into the Barricade (not using the WAN port) and your wireless N router will become a wireless accesspoint and you'll have a much simpler single network (not a network-in-a-network). Alternatevely you can probably turn your wireless N router into a wireless access point within it's administraqtion configuriration.
Or if you want the simplest method, with no tricks or new things to learn. return the wireless N router and get a wireless N access point (WAP) instead. It will make you life much easier.
Happy Woodworking!
