A55 Smoothing Plane
OT Computer Question
Steve in Fresno - GO Dogs!!
>I've gotten a new hard drive and want to more programs over. What is the best way to do this. Cut and paste is'nt working for me.
Thanks
Steve
Re: OT Computer Question
John McGaw
>Simply copying the files will not work, as you have discovered. You really need to find yourself a "drive cloning" tool. The maker of the new drive may have a free program on their website to do the job. Seagate's and Maxtor's program is a modified version of Acronis True Image and works a treat. Acronis itself is great but getting a free workable substitute is even better.
Basically what you do is to connect the new drive to the system, run the cloning program telling it to move the contents of old drive to the new one and it does the rest, scaling partitions up (or down) appropriately, setting the new disk up to boot properly, etc. Then you power down, disconnect the old drive, set the new drive as the boot device, power on and away you go.
Backup all documents
Chuck W
>What I would do before copying the OS from one drive to another, that is a good idea by the way, is to make a backup of all of your documents and files that cannot be replaced. Then if something should happen you will still have them if a reinstall of the OS becomes necessary. A good cloning program like Acronis will make the job very easy. By the way what kind of drive did you buy and what is the OS?
Spencer
>Easiest: backup via something like Acronis.
Best: Reinstall everyhing from scratch and manually copy your data (not programs) to the new drive. Windows gets messy with time and the installation of a new drive is a new time to begin anew. That said, if you *just* installed everything and then you had a drive failure, though, Acronis or the like is the way to go.
Alternative Driver Imager *LINK*
Curt Harms
>I use a sort of offbeat program that works well. I get it as an .iso image then burn it to a self-booting CD. Thing I like about it is Windows is not running at all when the image of Windows is being created. The resulting image is self booting so if required, insert the CD/DVD(make sure the CD/DVD drives boots before the HD), reboot and select what you want to do from the menu. I make at least 2 images; one with just the operating system, updates, drivers etc. A second image with applications. Has saved much angst.
HTH
Curt
Image For Linux
Offer has expired
Larry Marker
>Followed the link and it says, sorry - offer has expired.
Larry
